Can laser (lidar) diodes be installed in the headlights
Results 1 to 10 of 13
Thread: Can laser (lidar) diodes be installed in the headlights
    Jan 2011
    Just outside Montreal area
    Does anyone know if it is possible to put diodes from Laser Interceptor in the front headlights of the R8.
    I read in a laser/radar forum where some people where installing the diodes in the front headlights and wondered if it was possible to do so on the R8
    Phantom Black 2012 Spyder
    911 Turbo Cab2004
    993, 911 Cab
    E Type 67 Cab
    Senior Member SSIIICK's Avatar
    Boca Raton, FL
    Re: Can laser (lidar) diodes be installed in the headlights
    Quote Originally Posted by eliouno View Post
    I'm just curious why you would want to do that? It would be a real hassle and could easily be installed in the front grille, hiding it perfectly. The slots on the front grille of the R8 are almost too perfect for the little black boxes.
    2010 Audi R8 5.2
    Ibis White / Black
    Carbon Fiber Everywhere
    2009 Nissan GTR
    Black / Gray
    Too Many Mods
    Jan 2011
    Quote Originally Posted by SSIIICK View Post
    I'm not sure of how much trouble it is and that is why I am asking the question.
    The reason is that it would be much more stealth and that is the reason I ask
    PS Not sure what you mean when you say
    "front grille of the R8 are almost too perfect for the little black boxes"
    911 Turbo Cab2004
    993, 911 Cab
    E Type 67 Cab
    May 2011
    Topeka, KS
    I think he means that the slats are the perfect height, the colour is great at making the laser diodes steathy, and you can mount the boxes just in-board of the headlight; the perfect placement. Why bother with destroying an expensive headlight enclosure?
    Bish
    Boca Raton, FL
    Quote Originally Posted by thebishman View Post
    Bish
    Exactly!
    2010 Audi R8 5.2
    Ibis White / Black
    2009 Nissan GTR
    Black / Gray
    Too Many Mods
    Jan 2011
    Exactly!
    Not exactly sure which location you are referring to. Do you mean behind the grill itself next to the light or on the fins just below the lights. If you have a pic that would be super....thanks
    911 Turbo Cab2004
    993, 911 Cab
    E Type 67 Cab
    Boca Raton, FL
    I'm talking about the center grille, not the fins under the headlights. I have attached a photo for you to see.
    2010 Audi R8 5.2
    Ibis White / Black
    2009 Nissan GTR
    Black / Gray
    Too Many Mods
    Jan 2011
    Thanks for talking the time to take the photo, and have to agree, it makes more sense to do it there.
    I noticed that part of the grill seems to obstruct the diode. Does this not affect it at all
    Thanks again
    PS: where did you put the rear ones
    911 Turbo Cab2004
    993, 911 Cab
    E Type 67 Cab
    Boca Raton, FL
    Thanks again
    Believe it or not, I have been told that even two up front is overkill as one has the ability to cover the entire front end. I guess they have been doing two up front with one in the rear for so long it has become normal. I still suggest two up front as I believe it is better to be safe than sorry, even if it is overkill. For the rear, above the license plate is the most common so it doesn't stick out at all. I have also seen it installed in the engine compartment right behind the glass up top, but that was pretty crazy. The rear is almost pointless as you will most likely be hit with laser from the front only, but once again, better safe than sorry. Hope my explanation makes sense. Lol!
    2010 Audi R8 5.2
    Ibis White / Black
    2009 Nissan GTR
    Black / Gray
    Too Many Mods
    Jan 2011
    Make a lot of sense....and thanks for the input
    911 Turbo Cab2004
    993, 911 Cab
    E Type 67 Cab
  1. RV with R8 Headlights?
    By MotherTucker in forum Appearance / Body Modifications
    Last Post: 04-27-2012, 01:26 AM
  2. BMW to offer LASER headlights
    By freshmeat in forum Off Topic Discussions
    Last Post: 10-14-2011, 02:51 AM
  3. BMW developing laser headlights
    By randombloke in forum Off Topic Discussions
    Last Post: 09-06-2011, 09:53 AM
  4. Anyone with LED headlights?
    By spoon_sports808 in forum General Discussion
    Last Post: 07-01-2009, 07:30 PM
