Faulty Sensor
Results 1 to 10 of 11
Thread: Faulty Sensor
    Junior Member trance's Avatar
    Jul 2012
    manchester
    Faulty Sensor
    Hi, Can anyone tell me what the procedure is to replace a faulty "oil level sensor"?
    When I bought the car the service history stated that the local audi garage had cleared the fault code for the above, but advised that if the fault returned to replace the sensor. (dash is now lit up telling me to top oil up)
    When I release the engine bay cover the warning light goes out for 30 miles or so but then returns, I presume this is the boot switch letting the ecu know that there may have been an oil top up?
    Being in the motor trade ( light commercial van sales) I don't use main dealers, So I was looking to book this job in at one of the local workshop's that I use.
    And can you tell me where the vag-com connection port is situated? Thanks
    Kind Regards Sean
    Re: Faulty Sensor
    Interesting about the light going out after stopping and opening the hatch/boot/cover/what ever we want to call it.
    I'm guessing it has more to do with the car sitting for a moment and the oil settling in the system.
    I'm useless on a recommendation of a shop, but can tell you that the VAG-COM port is straight down below the driver's side window a/c outlet just before you get to the carpet in the footwell. Run your hand down the bottom of the dash there and you'll find it. There's no cover, just an open port.
    Re: Faulty Sensor
    You don't mention whether or not you checked the oil level and verified the car does not need oil.
    If you haven't, do so using the exact proceedure in the owner's manual.
    Always try the easy stuff first!
    Welcome to R8Talk. I'm here to keep R8Talk clean, running smoothly, and organized. Please read the FAQ: Audi R8 Introduction and Road Map. Since I can't read every post, or welcome every new member, I'd like you to help me out. Please PM me if you see anything on R8Talk which needs my attention. "I have quattro. Eat my dust."
    2012 R8 GT 5.2 6RT | 2009 R8 4.2 6MT (STāSIS S/C) | 2008 TT 3.2 6ST | 2004 S4 Avant 4.2 6MT | 2010 ZR1 6.2 6MT | 2002 Z3 M Coupe 3.2 6MT
    Jul 2012
    manchester
    Re: Faulty Sensor
    Oil level is fine, Thats the first thing I checked, Looks like it will have to have a new oil sensor
    Just need to know the procedure for fitting it
    Jun 2010
    Re: Faulty Sensor
    Sorry to drag up an old thread, but did you have any joy with this?
    My oil temp gauge stopped working yesterday. Turned the car off and on again, and got 'oil level sensor defective' warning light. Turned off and on again (yes.. I work in IT...!) and the message didn't re-appear.
    I can live without the oil temp, but not oil-level - don't want to be running low on the gooey stuff!
    Jul 2012
    manchester
    Re: Faulty Sensor
    Quote Originally Posted by swisstoni View Post
    No joy, I never got round to fitting a new oil level switch, My oil level light has only flashed twice in the last 6 weeks so its only intermittent now and again,
    Think I will wait for the next service before I replace it
    Jun 2010
    Re: Faulty Sensor
    Mine's also changed to intermittent... some days it wont go off, other times it can go all week without flashing.
    I too will probably wait and see...!
    Jul 2012
    manchester
    Re: Faulty Sensor
    Done a bit of research and the part number for the oil sensor is the same as a Lamborghini gallardo... Part number 420907660
    You can order one here.... http://www.eurospares.co.uk/searchRe...&TA=1&TB=44003
    Jun 2010
    Re: Faulty Sensor
    Finally getting round to ordering one of these - error went quiet for a bit but has come back with a vengeance now!
    Was quoted £160 for part only (approx £550 if memory serves for fitted!) from local main dealer Audi garage!
    There's a fitting guide here for anyone who might want it in the future: http://elsaweb.spaghetticoder.org/do....05/31649760/3
    Looks very simple, so I'll give it a go myself and attempt to save £460....!
    Europe
    Re: Faulty Sensor
    so much to fit that? that's not even half an hour's worth of work. You can do it in a snap if you're OK with a screwdriver.
  1. Gas tank sensor malfunction?
    By r1lee in forum Maintenance and Service
    Last Post: 02-23-2013, 03:32 AM
  2. TPMS Sensor Help
    By JAMESY1010 in forum Wheel and Tire Discussion
    Last Post: 01-24-2013, 11:41 PM
  3. TPMS sensor adaptation...
    By NVRL8R8 in forum Wheel and Tire Discussion
    Last Post: 08-11-2011, 07:30 PM
  4. Outside temp sensor where?
    Last Post: 08-10-2009, 10:59 AM
  5. Electronic sensor on OEM rear brake pad
    By jr_spyder in forum Wheel and Tire Discussion
    Last Post: 10-14-2008, 11:38 AM
