battery dead how to open luggage compartment when emergency cord not working
Results 1 to 10 of 10
Thread: battery dead how to open luggage compartment when emergency cord not working
    Nov 2012
    CA
    Exclamation battery dead how to open luggage compartment when emergency cord not working
    Hello,
    I'm running into a serious issue. The battery of my R8V10 had completely drainned when I forgot the air conditioner. I cannot open the luggage compartment neither with the electric way or the cord under in the emergency box (under the glove box).
    I tried to charge the battery with POrsche Battery charger but it does not seem to be working.
    Can anyone let me know if there is another way to open the luggage compartment?
    Member feudal serf's Avatar
    Jun 2011
    Eastern Canada
    Re: battery dead how to open luggage compartment when emergency cord not working
    The cord under the foot wall is where your best bet is. It has to be pulled hard. Try it again.
    FS
    R8 V10 Black O2 Silver
    Nov 2012
    CA
    I have tried and it just stuck. My Audi advisor told me to pull it gently ("BE VERY CAREFUL AND GENTILE when pulling on that red release. If it feels like it is not working or not going to release, do not force it. It can break."), and if it is not going to work I need to tow the car to dealer !!! crying...
    How hard should I pull? Did you try very hard?
    Jun 2011
    Eastern Canada
    Bonnet/hood won't open!
    Here is a link to another problem, regarding incomplete opening of the hood.
    It shows a few pics of the actuator that opens, basically a plastic rectangle that can break.
    The problem is that the wire is long and it requires more force than you think. Also, this is not used much and will be relatively stiff. I opened mine with my fingers in the loop, others I think it was V10Spyderman who describes putting a small screw driver in the look to get better leverage, and some members mentioned that the loop felt like it was cutting into their fingers, they had to pull so hard.
    I suspect that there are varying degrees of force needed. Read through that link and try again.
    I'm puzzled by your audi advisor suggestion, except that ultimately you are pulling on a piece of plastic and they don't want you to blame them if it does break. What other choice do you have?
    Good luck with it.
    FS
    Europe
    I don't know if it would help at all but try to have someone apply some good downward pressure on the bonnet from the front while/before you pull, then pull and see if it helps...
    I had this problem just this week. I inadvertently knocked the little white plastic rectangle loose when replacing the trunk liner, and so of course the hood wouldn't open with the electric release. Understand that my hood is very easy to latch (much easier on this 2012 than on the 2009) but I still had to pull very hard on the emergency cable to get the trunk to open. I couldn't do it with my bare hand, I have too much aversion to pain. So I put a small end wrench through the loop and was able to pop the hood with a firm (but not massive) pull on the cable. Give it another try!
    Welcome to R8Talk. I'm here to keep R8Talk clean, running smoothly, and organized. Since I can't read every post, or welcome every new member, I'd like you to help me out. Please PM me if you see anything which needs my attention. Please read the FAQ: Audi R8 Introduction and Road Map "I have quattro. Eat my dust."
    2012 R8 GT 5.2 6RT | 2009 R8 4.2 6MT (STāSIS S/C) | 2008 TT 3.2 6ST | 2004 S4 Avant 4.2 6MT | 2010 ZR1 6.2 6MT | 2002 Z3 M Coupe 3.2 6MT
    Jan 2012
    Chester UK
    You need to find a point to recharge the battery, a good point is the starter motor, they usually have a large +ve cable direct from the battery, we used to have to do this with 944/968 Porsche
    Senior Member slammedr8's Avatar
    Apr 2010
    Toronto, Ontario
    Quote Originally Posted by thangdm View Post
    Hello,
    I have to ask...how did your battery die from leaving the air conditioner ON? Doesn't the a/c turn off when the car turns off....???
    Current:
    2013 Audi S4 - White on Red
    Coming Soon: R8 V10 Spyder - White on Red
    Previous:
    2011 Range Rover Sport Autobiography- White on Red- - GONE!
    2008 M6 Coupe - White on Red- - GONE!
    2008 M3 Cab - White on Red- - GONE!
    Hello,
    The lighter sockets are disconnected unless the car is powered on (key on).
    Nov 2012
    CA
    Quote Originally Posted by slammedr8 View Post
    ignition off but I still left key on and forgot the air conditioner turned on overnight after I had been so excited listening to the music shame on me.
  1. Battery dead, delivery mode?
    By R8_Sweden in forum Maintenance and Service
    Last Post: 04-09-2012, 05:30 AM
  2. Additional luggage compartment light
    By Radius8 in forum Appearance / Body Modifications
    Last Post: 09-11-2011, 03:29 PM
  3. Replies: 7
    Last Post: 03-18-2011, 04:52 PM
  4. Luggage Compartment CF
    By ianerrid in forum Appearance / Body Modifications
    Last Post: 08-25-2010, 04:47 AM
  5. Luggage Compartment
    By R8RUNNER in forum General Discussion
    Last Post: 09-24-2007, 05:38 AM
