Need help from every1 flood damage 2009 audi r8
Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Need help from every1 flood damage 2009 audi r8
    Dec 2012
    philadelphia pa
    Unhappy Need help from every1 flood damage 2009 audi r8
    My car got in flood from fresh water
    there is no power now but there was power when i took all the water out
    i called over 20 audi stealship and noteven 1 of them want 2 look at it
    insurance wont cover the car it was under dealrship name i nevr put on my name biggest mistake
    only way 2 fix this car is 2 find a donor audi r8 engine and trans good
    need all the wires navi ecu body control fuse box seats carpet it has 2 me 08-09 r8 auto
    and i am sorry if i posted in wrong place
    i hope u guys can help me
    my phone number is 215 356 5312 any help is great at the time
    Senior Member drifting's Avatar
    Dec 2010
    Idaho/new york/england for christmas :)
    Re: Need help from every1 any help would be great 2009 audi r8
    Right firstly how far did the water come up?
    Did the water go inside the car ie wet carpets?
    Was the car driven in the water or was it not running when the water hit?
    Don't try to start it at this point!!!!!!!!!!!!!!!!!!!!!!!
    Dec 2012
    philadelphia pa
    water got inside half way to seats
    it had power and start up after i take all the water out
    but now there is no power at all
    i order new fuse box still waiting 2 get it
    Dec 2010
    Right ok first things I would do is check the intakes see if they are wet at all? second pull the plugs and look into the bores to see if any water is in there. You don't want to compress water!
    Have you checked the battery has power and hasn't been damaged?
    If the battery has power get the current tester and start working away from the battery to see where the power stops.
    Its worth taking the ecus out and opening them up and drying them off.
    I think I would take the seats and carpet out gives you easier access.
    You should be able to dry a lot of things out and clean them up.
    Dec 2012
    philadelphia pa
    i took all the seats and carpet out
    there was no water in the engine
    i did oil change and all the fuilds change
    Dec 2010
    There is one good thing if there is no water in the motor
    Chase the power lines back if there is no power at all it must be one of the main fuses close or something fairly close to the battery.
    Is there any power going to the ecus?
    Dec 2012
    philadelphia pa
    yes i hear something when i take the ecu off and put them back
    Senior Member blackspyder's Avatar
    Dec 2011
    England
    i dont understand why a dealer wont fix it - this is what they are for.
    you pay them money, they do things...
    Dec 2012
    philadelphia pa
    i know right that is what i ask them 2 i told them i will pay cash they can even hold money before they start but they said they wont even touch flood r8
    Dec 2010
    Thats because audi dealers are just fitters they have no clue where to even start. in my expensince they struggle half the time to even service a car.
    You could do with getting the workshop and wiring manuals will make it much easier I'm sure one of them members can email it you.
  1. Replies: 76
    Last Post: 02-04-2013, 11:50 AM
  2. V10 alloy damage - repairable?
    By apj30 in forum Wheel and Tire Discussion
    Last Post: 10-16-2012, 04:43 AM
  3. WTB Audi R8 V8 (or V10) rear damage salvage car
    By MartinSung in forum Want To Buy - Vehicles
    Last Post: 01-12-2012, 10:24 PM
  4. Damage, dent and repair, to repaint the whole part or not?
    By M3R8 in forum Detailing & Car Care
    Last Post: 09-27-2011, 01:29 AM
  5. Would anyone buy a Cat D (minor damage) car (repaired)
    By andyhofer in forum General Discussion
    Last Post: 11-23-2009, 01:14 PM
