Manual V8 clutch going after 18k miles!? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Manual V8 clutch going after 18k miles!?
  1. #11
    Jul 2012
    uk
    Make sure its fully repaired before you buy, there could be anything once they start really digging around in there.
    V8 ice silver, cf side panels
    Jan 2012
    Chester UK
    Re: Manual V8 clutch going after 18k miles!?
    The only time I have ever changed a wheel bearing in recent years is when the car has for instance bumped a curb and destroyed the wheel, the bearing then follows some 5-10,000 mile later, I bought a TDi Golf for wifey and me as a second car, 35,000 mile (checked via Vagcom, diesels have a computed mileage stored in the ecu) the 2 O/S wheels on the car were quite new, I asked why, ''corrosion'' he said, replaced by VW under warranty, odd how both offside front and rear bearings failed within 10,000 miles of ownership!
  4. #13
    Apr 2010
    Birmingham, UK
    Audi changed my clutch under warranty on my V10 at 12K. I only had to pay for the flywheel (£900). The clutch died only a week after buying the car but I bought it privately so they had no obligation to help me. I had to have my clutch changed on my V8 at 40K it cost me £2K but I had it done by my indy and they only charged me £400 labor.
    V210 - Silver / Black with full CF and part leather
    V6 - Orange / blue - sold and missed
    m3 09 my best car ever
  5. #14
    Member Veegan's Avatar
    Jul 2011
    London, UK (and Staffs)
    Quote Originally Posted by dazmac13 View Post
    Does this not seem ridiculously early for a manual to need a new clutch?? although i guess if the owner cant drive it properly anything is possible. im absolutely gutted as i thought i'd found a peach of car. not a single warranty issue in 3 years and now it needs £5k worth of repairs!
    I think most people with manuals here have only had clutch wear issues nearer the 40k mark. That your potential buy is needing a new clutch at 18k should raise alarm bells. In the absence of outright mileage fraud it points to a bad driver who at the least is mechanically insensitive.
    Also, no warranty issues in three years may be because the car has had no problems, or it may be because the owner has not cared enough to get small problems/niggles looked at.
    Additionally, no problems with the shock absorbers in three years on London's roads? Seems as though they may be on borrowed time and leaking shocks can be hard to pick up, even by Audi. £800 a corner if one goes...
    V.
    2008 V8, Phantom Black, Lava Grey Blades, all the toys...
  6. #15
    Member JDH_UK's Avatar
    Feb 2012
    Leeds, UK
    Quote Originally Posted by Veegan View Post
    V.
    I had a leaking shock replaced under warranty last year and was told it would have been £980 for the part alone, seems to be a big fluctuation in the cost of parts across dealers. I can understand different labour rates but surely there should be some consistency in the cost of parts?
    Current:
    2009 R8 V8 - Phantom Black with Carbon Blades / Luxor Beige
    Past:
    1990 964 Carerra 4 Widebody
    1991 964 Carerra 2 Widebody
    1986 Audi UR Quattro
  7. #16
    Jan 2012
    Chester UK
    V.
    I agree with you here, Audi will only usually respond if you point out faults to them, Porsche are the same, customer brought me a C2911 some years ago complaing of a heavy clutch, car was under OEM warranty, I told him he needed a new clutch, Porsche told him it just needed bleeding, then it need new polywhatsit bearings on the release arm, then Porsche said it was ok as it didn't slip anyway.
    I put him a new clutch in it and the pedal pressure reduced that much he was convinced it would slip.........but it didn't.
    I guess the point is if the original owner either doesn't notice the faults, or can't be bothered booking the car in the faults will remain, hence no warranty claims in the cars history
  8. #17
    Jul 2011
    Quote Originally Posted by JDH_UK View Post
    I was quoted £800 for the part both by my dealership and also by an independent (as an honesty check).
  9. #18
    Jul 2011
    Quote Originally Posted by mikef4uk View Post
    I took my car in for its first MOT right at the tail end of the warranty period and told Audi the nearside rear shock had gone. They duly replaced it under warranty. A few days later, the offside rear shock goes as well! Happily, Audi picked up the tab for the second shock out of 'goodwill' as the warranty had ended but I was disappointed that they hadn't picked it up when doing the MOT.
  10. #19
    Jan 2013
    england
    The rear wheel bearings are, believe it or not, the same as a vw scirocco, as is a lot of the other components of the rear suspension
  11. #20
    Feb 2012
    Leeds, UK
    It clearly pays to shop around. All 3 of my nearest Audi dealerships (Leeds, Wakefield and Huddersfield) are owned by the same company so will need to travel further afield to find one that isn't.
    Current:
    Past:
  1. How many miles did your clutch last?
    By bobbyo in forum General Discussion
    Last Post: 12-18-2012, 02:49 PM
  2. UK V10, 59 plate, 13K miles, 10K extras, new clutch
    By mark25 in forum For Sale - Vehicles
    Last Post: 08-20-2012, 01:42 AM
  3. Manual Clutch Problem
    By nbw888 in forum Maintenance and Service
    Last Post: 04-28-2012, 11:23 AM
  4. V8 6-speed clutch (plenty of miles left).
    By lightninhopkins in forum For Sale - Parts
    Last Post: 04-25-2012, 11:51 AM
