Clutch Rattle
Results 1 to 7 of 7
Thread: Clutch Rattle
    Jun 2011
    Cheshire, England
    Clutch Rattle
    Hi, I've just purchased my first R8 a week ago! Its a 2008 4.2V8 Manual which has covered just over 4000 miles. I've noticed that when the car is ticking over on the drive there is a rattling noise from the engine which dissapears when the clutch peddle is pressed. As soon as you release the cluch peddle it comes back. Is this something I should be worried about or is it normal on R8's? To me it sounds like something is dry when the clutch is engaged. If anyone could shed any light on this it would be a great help!
    Many thanks Ian.
    Dec 2008
    Twin Cities, Minnesota
    Re: Clutch Rattle
    Take it to the dealer. They are your best friend. They will do most anything to keep you happy and your car in perfect shape.
    Oct 2010
    NYC/NJ/CT
    Re: Clutch Rattle
    I have noticed the same thing in my V10 spyder recently. Sounds like what would be clutch spring rattling and/or throwout bearing noise in other vehicles I have driven...
    Will have the dealer check it out at the 5k service, but Iank have you found a resolution to your issue yet?
    Ibis White V10 Spyder
    Chawton White Land Rover LR3
    Silverstone Metallic Honda S2000
    Supporting Vendor
    Dec 2009
    Oakland, CA
    Re: Clutch Rattle
    Could do throwout bearing noises, which isn't great if the bearing is going south, or gear lash which is fine. Cars with fairly light flywheels in neutral with the clutch out will rattle usually and when you depress the clutch it loads up and goes away. Usually won't make the noise when you are in a gear either. Tell the dealer and hopefully nothing major.
    Alexander van Gerbig
    www.europrice.us
    contact@europrice.us
    Follow Europrice on Facebook
    Senior Member gazza1's Avatar
    Australia
    Re: Clutch Rattle
    I had a similar noise in my V8 coupe when I first had it in 2008 and it had done around 3000k.
    It never made the noise driving and the box and clutch worked perfect.
    I took it to the dealer and they replaced the gearbox under warranty no fuss and the noise never returned.
    It could be something else but I would have it checked.
    R8 V10 IBIS WHITE SPYDER
    R8 V8 IBIS WHITE COUPE
    NISSAN GTR R35
    Life Is Full Of Surprises.
    Oct 2010
    NYC/NJ/CT
    Re: Clutch Rattle
    Thanks for the info, I do plan on investigating further at the next service which is coming due soon. I've managed to put nearly 5k on the spyder in 4 months of ownership, so much for being a fair weather-only car...
    Member ldye's Avatar
    May 2010
    Gulf Shores, Al
    Re: Clutch Rattle
    Have the same noise. At the 5000 mile service, Audi field mgr did audio file and sent to corporate. Their response it is half shaft end play and is normal. I don't believe that is what it is. I think it's clutch chatter. I've brought it to audi's attention, so any issues later it will be their problem hopefully.
    2010 R8 White/blk 6Mt
    2011 BMW 135 vert
    2011 Mini Countryman S
  9. Remove Advertisements
  1. Something loose (rattle/ticking) below gear shifter? R-tronic?
    By soho in forum Maintenance and Service
    Last Post: 08-05-2011, 02:04 PM
  2. Found a potential rattle source R8ers should know about
    Last Post: 06-21-2011, 09:19 AM
  3. Spyder owners, rattle behind driver seat?
    By BlkwdwR8 in forum General Discussion
    Last Post: 12-23-2010, 04:46 PM
  4. RATTLE! How to remove door trim
    By MacR8A5 in forum General Discussion
    Last Post: 11-03-2009, 12:46 PM
  5. Replies: 0
    Last Post: 06-18-2008, 11:32 PM
