Can't open my engine cover...
Results 1 to 10 of 20
Thread: Can't open my engine cover...
    Aug 2010
    France
    Unhappy Can't open my engine cover...
    Hello,
    Today i just get a new problem on my R8...i can't open my engine cover !
    When i use the part which is close the driver door nothing happened.
    I guess that the cable is broken near the engine trunk (is that the correct name ?) because all is ok inside the car (i turn off the plastics).
    My question is : another solution is possible to open engine cover ? A drawing of that system is available ?
    Thanks for helping (and sorry for my english, i'm french ).
    Jan 2010
    Re: Can't open my engine cover...
    S'il vous plaît pourriez-vous ajouter votre emplacement à votre profil? Désolé, je ne suis pas sûr d'une autre façon de l'ouvrir.
    Does that make sense?
    Senior Member Rit2's Avatar
    Malaysia
    Quote Originally Posted by poopf1team View Post
    Hello,
    I had the same problem with the engine compartment lid.
    In my case, Audi replaced the defective solenoid which releases the latching mechanism of the engine compartment lid.
    The engine compartment lid can be released manually by pulling the (yellow) cable located behind the seats, protruding from underneath the rear-shelf.
    If you cannot find that manual release cable, it would mean that the cable was 'accidentally placed' INSIDE that rear-shelf. When you open that rear-shelf to gain access to the cable, make sure you leave the loop of that cable sticking-out from underneath that rear-shelf.
    Bonne Chance
    Europe
    Rit is exactly right. The loop is located near the corner of the shelf, behind the driver's seat (left side of the car).
    If you need to pop the shelf, be very careful in doing so, it requires a bit of force, but not too much, and it needs to go straight up rather than be pulled up from one side only.
    It's best you let your garage do it unless you need it opened urgently.
    Aug 2010
    France
    Hello,
    Thanks a lot for helping, i will try it later today.
    I need to open my engine cover because i need to add oil before going to the garage.
    Aug 2010
    France
    I just turn off the rear-shelf and didn't find anything wich look like a yellow cable.
    Here is a picture of what i see :
    Europe
    As far as I remember, it is a thin cable with a small ring attached to it, it may be yellow as mentioned here, and it can be hiding behind something.
    It should definitely be close to the right hand corner of the picture you made. Just keep on poking in that area. When I finished work in that are a few months back I made sure the ring sticks out from under the cover. It was well hidden before that. Also check the manual for hints on where it may be.
    If the add oil warning came up recently, and your distance to the dealer is short, then you shouldn't worry about it and just drive it there.
    Europe
    No mobile/bluetooth support in your car eh
    Aug 2010
    France
    Unfortunetly no...it was same for speed limiter but my garage install it !
    I will try to find that cable, it is on all cars (i guess it looks like fuel filler cable in engine bay)
    Senior Member RS4Cab's Avatar
    North of Boston, MA
    What year is your car? My 2009 manual shows mine here:
    http://s970.photobucket.com/albums/a...release001.jpg
    Also I remember reading on some years ignition needs to be on for lid to open by switch
  1. Looking for V8 CF engine cover
    By Moncho in forum Want To Buy - Parts
    Last Post: 04-04-2011, 10:36 AM
  2. Replies: 7
    Last Post: 03-18-2011, 04:52 PM
  3. LMS Engine Cover
    By bz888 in forum Appearance / Body Modifications
    Last Post: 03-10-2011, 04:56 PM
  4. Used engine cover? anyone?
    By darkmatter in forum Want To Buy - Parts
    Last Post: 03-02-2009, 06:14 PM
  5. Non-CF Engine Cover Plate?
    By darkmatter in forum General Discussion
    Last Post: 02-06-2009, 10:34 PM
