1st to 2nd gear change issue
Results 1 to 10 of 13
Thread: 1st to 2nd gear change issue
    Sep 2011
    lancashire
    Hi, I've had my R8 V8 manual for about 5 months, I noticed from day one that it doesn't seem to like changing from 1st to 2nd, its seems to be a bit stiff and awkward as you move the stick. It seems to be better when its warm, but not perfect.
    Is this a common problem ? the cars is 4 years old, mint 19k miles. still under extended Audi warranty etc.
    Any advice is greatly appreciated !
    Los Angeles
    Re: 1st to 2nd gear change issue
    This doesn't sound normal to me. I've read in other posts that Audi needs to adjust the cables from time to time. Sounds like a service check is in order.
    Aug 2011
    California
    It feels like the gears are waiting an extra moment to mesh, but when they do mesh, it's an extremely solid and precise feeling (more solid and mechanical-feeling than other gears). Right?
    I've experienced this too, on both manual V8's I've driven, including it getting better once warmed up.
    I'd say it's normal. Drive and enjoy.
    Cheers.
    Senior Member gazza1's Avatar
    Australia
    Quote Originally Posted by maegeri View Post
    Absolutely correct..it is part of every service I have had on my R8's.
    The cable adjusters are located on the gearbox and access is simple.
    If you have the right tech it turns a notchy or even a good box into a sublime shift.
    R8 V10 IBIS WHITE SPYDER
    R8 V8 IBIS WHITE COUPE
    NISSAN GTR R35
    Life Is Full Of Surprises.
    Feb 2011
    Cheeseland (WI), USA
    I had same issue and had the shifting mechanism changed. Works well now.
    Sep 2011
    lancashire
    Thank you all.....thats great info. - I'll get it checked out.
    Aug 2011
    California
    Let us know how it turns out.
    Cheers.
    Miami Beach, Florida
    I have had the same problem. Had my cables replaced twice already under warranty. There definitely is some design flaw.. Take it to the dealer.
    Aug 2011
    California
    Was the issue actually solved?
    Car is at dealer now. The tech thinks the shift forks need replacing. He is going to try and get me a new gearbox from Audi. The cables were swapped twice and they did not remedy the problem. According to the tech the cables are not adjustable. They fit in one way only.
  1. Issue with Service !
    By AL3ayali_Dubai in forum Maintenance and Service
    Last Post: 08-22-2011, 11:16 AM
  2. Help! PPI Roll Bar Issue
    By bz888 in forum Performance Modifications
    Last Post: 06-23-2011, 01:40 PM
  3. Rtronic issue
    By hguy in forum General Discussion
    Last Post: 04-11-2011, 06:55 PM
  4. MMI issue
    Last Post: 08-09-2009, 09:02 AM
  5. 3,000 mi....ANYONE HAVE THIS ISSUE?
    By WHITMAN in forum General Discussion
    Last Post: 01-28-2008, 05:11 PM
