My car is falling apart
Results 1 to 9 of 9
Thread: My car is falling apart
    Senior Member rawg's Avatar
    Oct 2010
    Vegas
    J/K, not in the true sense.
    This happened after I went through what initially looked like superificla water on a highway while raining; turned out to be more than superficial so to speak. Was running at around 55-60 mph. Noticed this rubber thingy sticking out of the right front wheel area when I got home. Can I still drive this car (without pulling the rubber out) to the dealership you think (or just pull it out and drive it to the dealer)?
    Audi Q5 Ibis White 2010 Prestige
    BMW 328i Monaco Blue coupe steptronic 2007 (gone)
    Audi R8 Brilliant Red R-tronic
    Wish list: F California
    Vancouver, Canada
    Re: My car is falling apart
    You can put that piece back in place by yourself. Open the hood and see how it is attached on the other side. Just re-attach it in the same way. I've done it a couple of times while I was cleaning the car and knocked that piece out of place. No need to bother your dealer with something like this.
    David
    Jan 2011
    Bay area, CA
    It's held in only by friction. Make sure you push it back all the way, there a bit of a soft snap feel.
    2011 V10 Coupe, RT. Ibis white, black side blades, limestone grey interior.
    Senior Member NASA R8's Avatar
    Jan 2009
    Santa Cruz Mountains, CA
    My '09 never came that lose but it kept coming lose. The Audi tech said they had a new part that had metal clips in rubber and they replace the old ones which were just rubber under warranty. You might see what your dealer can do for you. As stated above they are only friction fit with rubber or rubber with embedded metal.
    2009 R8 Ice Silver; Limestone Gray; Carbon Fiber Blades, Grill, & Diffuser
    2008 S4 Avant, Dolphin Gray
    Senior Member gazza1's Avatar
    Australia
    Similar thing has happened on my 3 month old coupe..but only peeking out of the guard.
    I put it back in place but it dropped back down after a while again.
    If they put a fix in the year changes ..it doesn't appear to work.
    Never had the same problem on my other R8's
    I let the dealer fix on next drive past.
    Current Car build quality is as tight as a drum..no other issues at all.
    R8 V10 IBIS WHITE SPYDER
    R8 V8 IBIS WHITE COUPE
    NISSAN GTR R35
    Life Is Full Of Surprises.
    Oct 2010
    Vegas
    ty, will try the DIY tips
    Senior Member NFS13's Avatar
    Lehigh Valley, PA
    I used a clear sealant caulk on my 08 that had thiis issue after I actually lost one. The sealant is strong enough to hold it, but still can be removed and cleaned when they add the clips at your next dealer visit.
    Europe
    Remove that rubber part, wash and clean it thoroughly (including the seam where it hooks up with the car), then dry it and place it in again.
    If it's relatively snug, it should not easily move again as when the bonnet is closed it's held in place with pressure. It's when the part is dusty/dirty that it slips out of place easier.
    Oct 2010
    Vegas
    Yup, DIY about popping hood worked, feels snug
  11. Remove Advertisements
  1. Battery panel keeps falling in the boot.
    By Inrev in forum General Discussion
    Last Post: 10-17-2008, 02:05 PM
