Squeaky brakes
Results 1 to 10 of 11
Thread: Squeaky brakes
    v10
    v10 is offline
    Senior Member v10's Avatar
    Jul 2011
    ()Arizona (x)Germany
    Squeaky brakes
    My R8's brakes started screeching fairly loud(during low speed braking) at around 600 miles and the problem seems to be getting worse. I only have about 1,000 miles on the car and I'm thinking about switching pads. Has anyone else had a problem with brake noise?
    2011 Audi R8 5.2 FSI
    2010 Dodge Viper ACR - sold
    2010 Corvette ZR1 - sold
    Jan 2010
    SoCal
    Re: Squeaky brakes
    There has been a fair amount of discussion on this topic previously, and your complaint is certainly not uncommon. You can use the "search" function to help find those earlier threads.
    Since no one else has chimed-in with a response yet, I'll give you my two cents....
    Brake squealing is caused by harmonic vibrations that resonate at the metal-to-metal contact points on the caliper and pads. This includes the pad’s metal backing plate where it contacts the pistons; all guide pins and retention clips; and also the caliper slide assembly for floating calipers.
    As others have suggested, lubrication of these metal-to-metal contact points with a high temperature anti seize compound is necessary to prevent the resonating and subsequent squealing.
    Any good brake mechanic should be able to eliminate the problem by disassembling the calipers, cleaning off any rust, applying a thin layer of anti seize compound to all metal-to-metal contact points, and reassembling everything.
    Hope that helps. Good luck to you and have a good day!
    v10
    v10 is offline
    Jul 2011
    Re: Squeaky brakes
    Thanks for the reply... I did search but I guess I was using the wrong criteria because I didn't find many threads. However, I do remember reading a thread here about brake noise so I know at least a few people have had a problem.
    I might just wait until my first service is due to have the brakes serviced... unless the noise gets even worse in the meantime.
    US
    Re: Squeaky brakes
    You might need to search for "breaks". That turned up some results, some people can't spell
    Junior Member tobs408's Avatar
    Oct 2011
    my house
    Re: Squeaky brakes
    road dirt, rust and brake dust buildup in the anti gassing cuts in the brake pads and you get noise from there also. a quick and easy way to clean your pads without having to pay labor is take the car out for a ride and perform 3 or 4 emergency stops and see if the noise goes away.
    v10
    v10 is offline
    Jul 2011
    Re: Squeaky brakes
    Quote Originally Posted by tobs408 View Post
    Thanks, I was thinking about doing that yesterday but it rained all day. I'm going to give it a try in about an hour.
    May 2011
    Topeka, KS
    Re: Squeaky brakes
    Quote Originally Posted by v10 View Post
    First, the R8 is a high performance car with a high performance braking system; it's not a Toyota. As such expect the brakes to be a little louder than a 'lesser' vehicle.
    However here are some things you can try:
    Bed the rotors and pads in properly. Find a poorly traveled road and stop from 50 mph down to 5 mph as quickly as possible without engaging the ABS. Let the brakes cool off for a few minutes then stop from 60 mph down to 5 mph. Repeat the process up to about 90 mph. Then drive for about 5-10 minutes without using the brakes if possible to allow everything to cool completely. You should now have good deposition of pad material on the rotor.
    If the above doesn't work, then have the back of the pads coated with 'Permatex ceramic anti-squeal brake lubricant' product. This works great; I've used it on my old GT-R which has notoriously noisy brakes and it even helped control the squeal of Carbotech race pads.
    Good luck,
    Bish
    Oct 2011
    my house
    Re: Squeaky brakes
    as bish stated that is a great way to bed in brake pads. if that does not help, you remove the pads and champer the leading edge of the pads to give a little "wiggle" room. i have found the anti squeal compound works great on the audi 6 and 8 piston caliper cars.
    Re: Squeaky brakes
    The OEM pads are already chamfered. When the pads are worn to about fifty percent the chamfer is also worn away, and the likelyhood of brake squeal increases.
    v10
    v10 is offline
    Jul 2011
    Re: Squeaky brakes
    Quote Originally Posted by thebishman View Post
    Good luck,
    Bish
    Thanks for the advice, I will give it a try. Sounds similar to the ZR1 brake burnishing procedure.
  1. Ceramic Brakes
    By technomania in forum Wheel and Tire Discussion
    Last Post: 04-21-2012, 10:48 AM
  2. Read if you have a squeaky back end
    By kthacher in forum Maintenance and Service
    Last Post: 09-22-2011, 03:03 AM
  3. R8 brakes
    By drifting in forum Wheel and Tire Discussion
    Last Post: 06-15-2011, 12:52 PM
  4. R8 v10 squeeking brakes
    By Rob Carlisle in forum Wheel and Tire Discussion
    Last Post: 02-14-2011, 02:57 PM
  5. Tyre's & Brakes
    By Daniel1250 in forum Wheel and Tire Discussion
    Last Post: 11-09-2010, 07:14 PM
