hey just wondered if anyone could let me know roughly how much i should be looking to pay in british pounds for a new clutch on my 4.2 2007 r8
thanks guys.
thanks guys.
Just had my clutch changed a few months ago. If you have an Audi garage do it you are looking at £4000 for parts and labor. If you use an independant mechanic you can get it down to £3000. Parts come to about £2,400. I managed to claim the flywheel under my extended warranty (thirdy party warranty) which helped soften the blow. So total cost for me was £2000.
thanks mark i think its a new clutch that i need i drove it saturday 2 weeks ago then went on holiday it was spot no problems before i left then i drove it monday and straight away sounded like the clutch was slipping it was like it happened whilst the car was sitting in the garage its only done 35k can anyone relate to this?
cheers
hiya everyone,
great website here = )
i saw a V10 GT clutch on oemplus.com
if and when the time does come around for a replacement, would this work well for a V8?
i just thought if i was replacing it, might as well put something presumably more durable in.
http://oemplus.com/index.php?main_pa...oducts_id=1190
cheers and thanks
As I have said before, I'm no mechanic, and my knowledge of clutches is non existent, so I have a quick question, does the clutch only wear when changing gear, or does it also wear when it is fully engaged, ie. in gear
My own view is :
Clutch pedal fully down = no wear
Clutch pedal fully out and in gear = no wear
Changing gear and engaging clutch = wear
Thanks for helping the ignorant.
