Castrol Edge Full Syn 5W40......
Results 1 to 9 of 9
Thread: Castrol Edge Full Syn 5W40......
    Mar 2011
    Los Angeles
    Is Castrol Edge Full Syn 5-40W the correct oil to use in the Untited States? That is what my Audi advisor said they use so I presume that is correct.Please verify...Thank You and Happy New Year to all!!!!!!!!!!!
    Los Angeles
    Re: Castrol Edge Full Syn 5W40......
    That's what I use and also carry a quart in my trunk. Happy New Year.
    Mar 2011
    Florida
    This is the link to Audi's Technical Service Bulletin of Engine Oils that meet Audi Quality Standards. Our R8's (except for GT) require oil that meet Audi Oil Quality Standard VW 502.
    http://microsites.audiusa.com/ngw/09..._1997-2012.pdf
    Mar 2011
    Los Angeles
    Thanks Sundowners but just looking for a 1 oil I should use. Not a list that makes me dizzy..is. Castrol the correct oil? Thanks again!
    Mar 2011
    Florida
    Quote Originally Posted by woodranch View Post
    Your question was already answered in the Thread, on the same topic, you started just one week ago: "http://www.r8talk.com/forums/5-gener...-oil-type.html." I guess your dizziness affects your memory.
    While you car is under warranty use the oil that Audi and your Dealer recommend.
    Mar 2011
    Los Angeles
    Morning Sundowner, sorry that came out wrong. I am a little confused because it seems that no one else got the same recommendation that I did on Castrol. I just want to be sure that is the correct oil instead of calling 5 Audi dealers. Thanks for your patience!
    Mar 2011
    Florida
    No problem. I believe you have several responses, including mine, in your prior thread (and one in this) that said their Dealer's recommended or they use Castrol EDGE with Syntec 5W40. Audi definitely recommends and approves of Castrol EDGE.
    There are many different opinions as to which is the "best" oil. Ask a dozen different individuals and you are likely to get many different opinions. Your safest course, while under warrantee, is to use Castrol EDGE with Syntec because Audi and your Dealer recommend it. Also, if you read some of the current reviews, Castrol EDGE is being recommended in the top tier of oils to use. Hope this helps.
    EDIT: After doing my own research I requested approval from Audi to use AMSOIL European Car Formula 5W40 (VW 505.01, VW 505.00 and VW 502 compliant) in my 2012 R8 V10. I just received that approval in an email from my Dealer's Service Director stating that he received approval from his AOA FTS (Area Rep) this morning. AMSOIL is NOT on Audi's list of approved oils and is NOT available in retail stores.
    @ woodranch: just to close the loop on this, it is also prudent to mention that some of the recommendations you received in that other thread were from owners in Canada, OZ, and Europe where different oil branding/flavors are offered by the manufacturers vs those you can easily source in Los Angeles.
    Mar 2011
    Los Angeles
    Thank you Sunflower and Desperado....Happy New Year again and appreciate the help!
  11. Remove Advertisements
  1. DRL on full LED headlights on V8...same as on V10?
    By SebringSilver in forum General Discussion
    Last Post: 08-31-2011, 07:09 AM
  2. Diy retrofit oem full led
    By bubblerage in forum Appearance / Body Modifications
    Last Post: 08-09-2011, 01:47 PM
  3. Porsche GT3 Cup full
    By Bodhii in forum Off Topic Discussions
    Last Post: 12-07-2009, 09:39 AM
  4. full LED headlights in v8?
    By arunraja7 in forum General Discussion
    Last Post: 01-26-2009, 11:20 AM
  5. Full listing ... almost
    By Paul in forum General Discussion
    Last Post: 11-17-2006, 03:58 AM
