Gearbox malfunction - Please advice
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Gearbox malfunction - Please advice
    Member mrayes's Avatar
    Apr 2012
    Bahrain
    Exclamation Gearbox malfunction - Please advice
    Hey everybody,
    I have a 2008 Audi R8, i went out in a cruise tonight and stepped on the pedal several of times against a mercedes E63, 20 minutes after that i parked to get some food and kept the engine running. When I came back I tried to reverse the car and it was not moving. (the car is not moving in reverse or drive). A warning message (Gearbox Malfunction) appeared.
    I shut off the engine and kept the car to cool down for 20 minutes, i started the engine again and this time i could not put the gear on D or R, it stayed on neutral and the Gearbox Malfunction message kept appearing.
    The car is now towed to the dealer.
    I tried googling this issue but could not find anything, i really hope is isnt something expensive.
    Please advice, ill appreciate your help.
    PS: the car already done 61,000 km
    UPDATE: Just came back from the dealer and it's a clutch issue, the clutch wear measure was at 1327 (its suppose to be between 3000 - 8000, the higher the number the more it wears/any number outside this range means you need to replace the clutch).
    UPDATE 2: I ordered the clutch (Part Number 079141011E), Bearing (086141671D), seals, bolts and 4 brake pads from Audi Henderson Parts for $2848. All of these parts at my local dealer was for $5220. I think the shipping from USA to Bahrain will cost me $400
    UPDATE 3: The parts arrived today and I verified it with the dealer, all parts are ok. They will start working on my car tomorrow morning
    UPDATE 4: I received my car from the dealer last night and took it for a ride, everything seems alright and the shifting of the gear is smooth. I'll give you guys the final update after using the car for 3 more days
    UPDATE 5: Car is smooth and drives perfectly, I guess this case is now closed
    Case Closed
    Dec 2008
    Twin Cities, Minnesota
    Re: Gearbox malfunction - Please advice
    There are two threads that I posted on this issue. One in June of 2010. There are two sensors on the gearbox that must agree with each other. If they do not agree you will get the "gearbox malfunction". One of these sensor probably stopped working. Mine was covered under warranty. Audi knows about this issue so they MAY fix it under MFG warranty. It is a cheap sensor, but expensive install.
    Senior Member SaigonR8's Avatar
    Jul 2011
    Indochina
    I had exactly the same after some spirited testing of the Heffner TT hardware. It was the fuse that had been dislodged. Best of luck with yours.
    Apr 2012
    Bahrain
    Thank you for your replies guys, i really hope its not something very expensive like the clutch or the gearbox itself
    Anyone knows why this happens? ive changed a sensor in the gear few months ago but the car was moving normally. Now its not moving at all
    Jul 2011
    Indochina
    If you hit a large rut in the road whilst playing with the Merc that could be enough to dislodge or even break the fuse. No drama to replace. Sometimes it can be the simplest things ...
  8. #6
    Apr 2012
    Bahrain
    Thanks for your posts Saigon, its Friday here in the middle east and the dealer is closed. They will be open tomorrow and ill keep you updated.
    I really hope its only the fuse, one of my friends faced the same problem and the dealer told him it was the clutch (Part+Labor costs around $4,300 here)
    I really appreciate your feedback guys, Thank you again
  9. #7
    Apr 2012
    Bahrain
    UPDATE: Just came back from the dealer and it's a clutch issue, the clutch wear measure was at 1327 (its suppose to be between 3000 - 8000, the higher the number the more it wears).
  10. #8
    Scottsdale, AZ
    R-tronic or MT6?
    Here in the States, Audi is supposedly replacing the R-tronic clutches free the first time. Don't know if that's going to be the case in Bahrain, though. Worth the ask.
    It's the exact same clutch regardless of whether it's an R-tronic or MT6. Don't know if it would be worth while to upgrade to a V10 clutch or not being that it's a wear issue. (and not sure if you can talk the dealership into it either)
    Great F1 race there in Bahrain, btw. One of the best I've seen in a while - GO KIMI!!! The Iceman cometh!
    Hidden Content
    2017 Ara Blue V10 Plus - I've joined the Gen 2 side.
    2011 Samoa Orange V8 R-tronic - Loved dearly, driven daily.
    2009 Daytona Grey V8 - the Twin Turdbo, a complete lemon.
    2008 Daytona Grey V8 - Loved, driven, killed by a tree. Drats.
  11. #9
    R-tronic or MT6?
    You know better than that - only the R-Tronic has a clutch position sensor and thus a wear indication.
    2014 R8 LMS Ultra GT3 | 2012 R8 GT Coupe 5.2 6RT | 2009 R8 Coupe 4.2 6MT
    Welcome to R8Talk. Please read the FAQ: Audi R8 Introduction and Road Map.
    When I look fast, I'm not smooth and I am going slowly. And when I look slow, I am smooth and going fast. - Alain Prost
    The slower you move, the faster the car moves. - Ross Bentley
    The wise are instructed by reason, the average by experience, the simple by necessity, and the indifferent by instinct.
  12. #10
    Scottsdale, AZ
    Ah, now I do know. I wasn't aware of this. (or just never paid attention.... the more likely answer )
    Hidden Content
  1. R-Tronic Malfunction
    Last Post: 02-13-2016, 09:31 PM
  2. Gearbox Malfunction
    By tangk88 in forum Maintenance and Service
    Last Post: 02-07-2016, 02:19 PM
  3. Gearbox Malfunction
    By shawndama in forum Maintenance and Service
    Last Post: 12-18-2011, 12:55 PM
  4. GEARBOX MALFUNCTION code
    Last Post: 12-28-2010, 04:41 AM
  5. Gearbox malfunction
    By Levan in forum General Discussion
    Last Post: 02-21-2010, 08:16 PM
