Brake fluid intervals
Results 1 to 7 of 7
Thread: Brake fluid intervals
    Feb 2011
    London
    I'm tempted to have my brake fluid changed as my garage is going to be removing the trim over the reservoir to replace a wind seal. The car is less than 3 years old and I have no softness in the pedal but it seems like a good opportunity. Audi say the fluid doesn't need changing for 3 years from new but subsequently every 2 years. Does anyone know why the variation in schedule?
    Sent from my Autoguide iPhone app
    Re: Brake fluid intervals
    Changing it out is never a bad idea. Even as well sealed as modern automotive brake systems are, humidity (water) can work it's way into the system which is what degrades the brake fluid.
    Brake fluid (other than DOT5 - the silicone stuff) is glycol-based and hygroscopic, which means that it absorbs water. Adding water lowers the boiling point of the fluid, which can lead to fad and loss of braking power as the system gets hot - not a good thing at all!
    Get your garage to put Motul RBF 600 in it and you'll have a happy brake system.
    Bleeding the system is readily accomplished by using a pressure bleed system - you feed the res from a pressurized bottle that forces all the old fluid out of the system. A pressurized bleeding also helps get the ABS module's fluid flushed.
    Start at the wheel closest to the master cylinder first (would be the front right on a right hand drive vehicle), doing the inner bleeder first then the outer bleeder. Next would be the the left front, then right rear and finally left rear (always doing the inner then outer bleeders).
    The fluid will change color as the new stuff comes in - can be quite subtle but a good eye will notice the change as the old stuff gets pushed out and the new stuff arrives.
    Feb 2011
    London
    Thanks kfab. I'm using Audi so will have to talk them into using something non-standard - try don't even want to put V10 air deflectors on for the brakes "in case a stone is deflected into the brake" and I crash! Is the service period on Motul the same as Audi's generic fluid?
    I was wondering whether the reason for the longer first interval is guaranteed fresh / uncorrupted fluid from the factory vs the open can at the dealer's (!).
    Europe
    Resurrecting an old thread.
    My car is up for brake fluid change. What is the quantity I need to buy?
    Also, I noticed that sellers of Motul RBF 600 it's not to be used on street cars, only racing cars, why? makes no sense to me. In any case our R8s are not exactly normal street cars.
    I just did a brake fluid "heavy bleed", but not necessarily a full flush. I used just under two pints of RBF 600. I'm guessing a full exchange might take twice that? -- Okay, I just looked it up and the official stated capacity of the brake system on a 2010 R8 is 1.0L (1.1 qt) of DOT4 fluid.
    Welcome to R8Talk. I'm here to keep R8Talk clean, running smoothly, and organized. Please read the FAQ: Audi R8 Introduction and Road Map. Since I can't read every post, or welcome every new member, I'd like you to help me out. Please PM me if you see anything on R8Talk which needs my attention. "I have quattro. Eat my dust."
    2012 R8 GT 5.2 6RT | 2009 R8 4.2 6MT (STāSIS S/C) | 2008 TT 3.2 6ST | 2004 S4 Avant 4.2 6MT | 2010 ZR1 6.2 6MT | 2002 Z3 M Coupe 3.2 6MT
    Europe
    Thanks desperado. How about the RBF600, is it also recommended for a car that's not being tracked at all?
    The RBF 600 will be fine. I don't think there is anything about "good" brake fluid which would make it less suited for a daily driver than an "okay" brake fluid. They all "meet or exceed" the DOT 4 requirements.
    You can spend from USD$7/qt(lt) to $80/pint(500ml) for brake fluid. In return you get increasing wet boiling point. This can be important with the very high brake temperatures reached on the track.
    For a car which is never tracked, you would be fine with a standard or medium grade of fluid. A good value compromise between the two ends of the spectrum is the ATE brake fluid, available in two colors with the same/similar properties: Type 200 (amber) and Super Blue Racing. Alternating between the two colors at each flush gives a clear indicator of when the new fluid has reached the caliper.
  9. Remove Advertisements
  1. Accessing Brake Fluid Reservoir
    Last Post: 05-06-2013, 10:55 PM
  2. access port for brake fluid reservoir
    By willyjp in forum Maintenance and Service
    Last Post: 12-21-2011, 09:31 AM
  3. Brake Fluid Change - Price Difference?
    By andyhofer in forum Maintenance and Service
    Last Post: 09-01-2011, 10:08 AM
  4. R8 BRAKE FLUID - heads up for track use!!
    By Craig@Rennstore.com in forum Wheel and Tire Discussion
    Last Post: 11-13-2008, 08:46 AM
  5. Boiling brake fluid
    By jr_spyder in forum Performance Modifications
    Last Post: 10-02-2008, 12:12 PM
