If you have the plateless front grill, just add a couple of small spacers (probably 3-4mm tall) between the plate and the bumper, to keep the plate straight, put a small piece of double sided sticky foam tape between the middle of the top of the plate (between the mounting holes) to keep the plate from moving around or rattling against the front bumper strip and use self tapping screws to hold the plate on.
I'd look into stainless steel self tappers - or go to the local car audio shop and tell them that you need some 6mm self tappers for plastic - they'll have a larger, more course thread with a more aggressive helix - will bite into the plastic and not tend to work their way out or wallow around after a while.
If you run the plate flat against the bumper it's going to give it a "just stuck on" look and the plate's not going to want to follow the bend w/o trying to warp a tad (usually in a diagonal manner). Keeping the plate flat and spacing it a tad will look much more professional. You could top that off with some sort of plate frame to clean up the look even more.
Thanks.
Steve
LinkBack URL
About LinkBacks
Reply
Beautiful!
CRF450R
The 10Dez
The Beast
The Berg
The Gen IV
