I've been trying to figure out how to modify the shift knob on my car for a while. I like the knurling, I like the shape, but it's sort of generic in a way. There's nothing that says "exotic" sitting there surrounded by carbon weave.
I've tossed around the idea of wrapping a knob in carbon. I've tossed around the idea of making a carbon sleeve that replaces the knurling.
I've had a few other ideas too, but I digress.
So today I felt creative. I decided that I was going to copy and/or modify the OEM shifter and put my own touch on it. Wasn't sure what I was going to do exactly until I started unscrewing it.
That's odd - the knurling seems to have rotated...
Sure enough, the knurling spins and that means it's a separate piece. That means this thing comes apart! (I'm good at taking things apart - sometimes not so good putting things back together - at least on the first attempts....)
So off I went trying to figure out how it comes apart.
I used a stylus and was able to push the shifter pattern button out of the aluminum body. Cool. I thought it was a thick sticker. And, I sort of had this plan in mind yesterday when I picked up the car (new clutch master cylinder seems to have solved the issue thus far), so I ordered a new button. The full knob is US$365, the button was US$69.59.
The top of the shifter has three holes. One in the center with some sort of plastic puck under it and a pair offset under the button - assembly holes!
Since my knob was already sort of scratched up, I decided to try and work it apart.
I already had plans to make a new knob, so this one was going to become the sacrificial lamb. I chucked it up in the lathe and started working out a non-tapered section so I could clamp it in the vice. I worked right up against the knurled ring so I could get it off (hopefully).
After putting it in a vice and going after it with pliers, it was toast, but I was in. Green locktite is a beast and I ended up twisting the center of the lower body in two - the threaded end stayed in the upper half.
I was right - there are two body parts, a knurled ring that's held in place with an o-ring and then a hard plastic sleeve that secures the knob to the top of the shift lever. It's like the nylon ring in a lock nut. The two pieces on the left side of the picture are supposed to be one piece.
Now my dilemma was what to make the body out of?
I had just the thing sitting on the shelf.
Titanium has a cool color, is tough, doesn't scratch, is "exotic" and just seemed like the right stuff for the project. It's fun to work with too. Nice, clean, doesn't make sharp chips & stringers. It DOES catch on fire like magnesium, though. I'd heard this was the case, and today I proved it! Fortunately it was a very small fire and fizzled out in a couple of seconds. It's not as bright as magnesium either.
Here's the bottom half in process:
Testing the fit between the bottom half and the knurled ring:
Here's the bottom half and the knurled ring being test fit against the top piece. I was still doing the bottom profile work and threading.
The final item!
Installed:
It's subtle, but I'm really pleased with the results. It took me about seven hours from start to finish.
LinkBack URL
About LinkBacks
Beautiful!
CRF450R
The 10Dez
The Beast
The Berg
The Gen IV
Reply
American Muscle
Audi Tourist Trophy
R8 GT
STāSIS R8
The Shoe
Yawning Maw
2001 Audi S4
8,R8 V8,Paddles,Mag ride,Jet-Blue/Carbon blades,Smoke chrome OEM 5 spokes & Lambo S.L. whls,Miltek exh.PPI Steering whl,rear wing,front grill,air filter kit.C.F.interior trim,V10 sideskirts,premium black leather,B&O,navi,camara. KEEPURSHINEYSIDEUP/STICKYSIDEDOWN VIDEO:R8 in CANYON video ... janerinsurance.com/r8 ...\"/
(just messing w/ya)
