VAGCOM - Rear Tail Lights
Results 1 to 8 of 8
Thread: VAGCOM - Rear Tail Lights
    Jan 2011
    COLUMBUS OH
    I have 09 R8.
    I know there are other threads, but they didn't help me with regards to keeping the rear tail lights on as DRL and the convenience window with remote. I am mainly concerned with the rear lights. I would like to keep them on to match the front. I fixed the winking issue and the seat belt chime. Any help would be appreciated.
    Europe
    Re: VAGCOM - Rear Tail Lights
    I'd appreciate to know how to get rid of the seat belt chime...
    Feb 2011
    Bay Area, CA
    Anyone in the bay area can help me with turn on my DRL when blinking? Thanks
    Vancouver, Canada
    I don't think anyone's figured out how to get the remote to open/close the windows yet.
    David
    Jan 2010
    Fortunately my R8 opens and closes windows with the remote from the factory which is nice.
    I know there is a KVW100 which works on VW but not sure it works plug and play on Audi.
    Jan 2011
    COLUMBUS OH
    I'm not sure if the version matters. i have VCDS 10.6.3. Just got into SELECT CONTROL MODULE, then GO into 17-INSTRUMENTS, I think coding then Long code helper. Tab over in the BYTE and look for the seat belt and I think you can in activate. I followed this person MotherTucker "Well I did succeed in turning off my seatbelt chime. In Module 17 (Instruments) Control Code, I set the second digit from the right (previously an 8) to a zero." If you can't find it, let me know I will get exact instructions and plug in the vag com. I just did it a few days ago. Let me know.
    Jan 2011
    COLUMBUS OH
    I just plugged VAGCOM in. Go into 17 Instruments, Coding - 07, then in the first box it says Software coding (0 - 8388607) then a box with numbers in there that you can change which after changing it mine has these numbers:
    0085208. Basically the seat belt chime is the question mark one. XXXXX?X. I think default it is set as 8. Just change it to 0 to inactivate the chime.
    Europe
    Thanks. I appreciate it.
  10. Remove Advertisements
  1. GT Tail Lights
    By ktdre in forum Appearance / Body Modifications
    Last Post: 05-20-2012, 09:08 AM
  2. How To: Rear Bumper and Tail Light replacement
    By KfabR8 in forum Appearance / Body Modifications
    Last Post: 04-03-2012, 07:35 PM
  3. LED License Plate Lights/Door Lights Report
    By Falcon Flyer in forum Appearance / Body Modifications
    Last Post: 10-11-2011, 12:16 AM
  4. F/S:R8 V10 5.2 Tail Lights Set
    By wickedrsr in forum For Sale - Parts
    Last Post: 08-10-2011, 05:38 AM
  5. US Spec tail lights & engine bay trim
    By KfabR8 in forum For Sale - Parts
    Last Post: 10-08-2009, 07:06 PM
