It would appear that the 2011 YM cars have a different control system than previous years. - or the control system for the tail lights has been relocated to some spot that I can't access (yet) w/the VCDS system.
Since I know of a couple people on the board that are wanting to install the GT lights, I figured I'd start a diagnostic thread and walk through what I've been through thus far:
The GT tail lights have the Euro-spec amber blinker strip in them. You have to reprogram your car so that it recognizes this. If not, the amber strip will light up every time you hit the brakes and when you use your turn signal. It's piggybacked with the brake light.
When I discovered that I couldn't (yet) separate the system via the VCDS, I decided to go to the wire harness and pull the one line that controls the amber strip out of the plug. (you must have the correct tools to do this - do NOT just try to pull the wire out or you will, guaranteed, destroy the wire). This will allow me to drive the car w/o fear of LEO stopping me for funky lights.
Some quick checking and I have the wire harness mapped out
Plug (on the NA tail lights) has six leads:
- Black - Tail Light Ground
- Black - Reverse Ground (larger gauge)
- Green - Reverse Activation (larger gauge)
- Blue - Brake Activation. Resistance of 325K ohms
- Yellow - this is the one I'll discuss in a minute
- Red - Tail light activation Resistance of 290K ohms
Being that wire #5 (yellow) seems to be an open circuit I'm confused by what I'm finding. If the car didn't see a circuit here originally, then why is it now trying to report back an open circuit? The only thing I can think of is since the pulled lead (the lead that activates the amber strip - which is active; piggy backed on the brake circuit) saw a load now the control system wants to see a load? Makes no sense...
When I pulled the lead that activates the amber blinker out of the harness, this should have "informed" the control that there was an open circuit (as per the NA tail lights). No, of course not. I'm getting left and right blinker codes on the dash display. It thinks there's a lamp out. - think similar issues with the LED license plate lamps.
It now would appear that the car is searching for a signal light. I have to wonder if the GT tail lights have a different resistance in each circuit?
I'm not ready to pull a wheel and inner fender liner to see what the GT's plug maps out to (yet). When I do, I'll post findings.
I'm waiting on Alex at Europrice to get back in touch with me - he has a VCDS Ninja working on some projects that have had similar issues. Hopefully he'll be able to help me hack into the system and find the coding for separating the running/brake and signal lights. I'll report back as soon as I get more info.
LinkBack URL
About LinkBacks
Beautiful!
CRF450R
The 10Dez
The Beast
The Berg
The Gen IV
Reply
2001 Audi S4
