Diy retrofit oem full led
Results 1 to 3 of 3
Thread: Diy retrofit oem full led
    Belgium
    DIY RETROFIT OEM FULL LED headLight for AUDI R8 (2007/2008/2009) no 2010 !
    On central electronic modul "8P0 907 279P" ( upside fusible modul , passenger side)
    if you have not this version (check on VAGcom) -> you must be change by 8P0 907 279P (because only 8P0 907 279P support LED and other no !!)
    You have A,B,C,D and G plug and more
    Folow step :
    1. Plug D pin 2 -> must be connecting with « black/grey » wire for fan ( pin 13 on headlight )
    2. Swap on plug folow wiring Pin ( you can order special OEM pin wire for perfect working : => 000979009E + 000979025E + 000979151E
    A5 -> A4 ( plug A pin 5 to plug A pin 4)
    D10 -> C3
    D6 -> G3
    C12 -> D6
    A5 -> A4
    B1 -> A5
    B4 -> C12
    D10-> C3
    3. Pull off plastic on around front luggage and disconnect plug of headlight
    Replace Head light (3 screw)
    4. Use VAGcom to activate LED front light
    More pics view FiftyPence post : VAG-COM Diagnostic Thread
    5. Test !
    6. Enjoy
    Jan 2010
    Re: Diy retrofit oem full led
    Superb, thanks for sharing with us bubblerage.
    Europe
    You're the same bubblerage selling R8 parts on ebay eh... cool.
  1. V10 LED DRL Retrofit
    By FiftyPence in forum OEMplus
    Last Post: 07-17-2011, 03:21 PM
  2. Navigation Retrofit?
    By pw78 in forum General Discussion
    Last Post: 04-01-2011, 04:53 PM
  3. Retrofit HBA
    Last Post: 01-05-2010, 11:20 AM
  4. Retrofit of nav in premium pkg R8 possible?
    By gsmps in forum General Discussion
    Last Post: 01-14-2009, 07:14 AM
  5. Is B&O sound possible retrofit?
    By Gord59 in forum General Discussion
    Last Post: 04-21-2008, 01:19 PM
