Alternative gear lever? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Alternative gear lever?
  1. #11
    Senior Member R_8cho's Avatar
    Jul 2019
    Re: Alternative gear lever?
    I like them both. Nice work. What is most annoying is that the + and - are opposite of bmw (and now porsche) for manual shifting. Altho with paddle extensions you really dont even need it
    Nov 2018
    Quote Originally Posted by R_8cho View Post
    That’s one of the reason why I’ve stopped using the lever all together.
    I can open up the lower unit and try switching +/-. I am not sure if it is worth it though...
  4. #13
    Jul 2019
    Quote Originally Posted by 2old4this View Post
    Not worth it and the fact that the +/- are still opposite on the trim piece would confuse me even more, lol
    Nov 2018
    Finally done with laminating the top cover with CF.
    As usual with any CF work I do, it took longer than anticipated.
    After removing the leather cover, I realized the top of the cover piece is actually some rubbery compound. Trimming it down to bare minimum took a little while (after all, one cannot send it down )
    Then I wrapped it with 2x2 twill CF, and applied something like a billion layers of resin (seriously, I lost count how many layers, probably 8 to 10), while sanding and smoothing between the layers. Once I had the imperfections gone, i sanded the whole thing with 240, 400, 600, 800, 1000, 1500, 2000, 3000 grit sand papers. As the last step, I used headlight-restorer from Meguiar (it really ends up with very clear looking results.)
    I am kind of happy with the result, except, it looks more glassy than the OEM CF. Need to find a way to tone it down...
  7. Remove Advertisements
