Alignment - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Alignment
  1. #11
    Aug 2016
    South Wales. UK
    Re: Alignment
    Quote Originally Posted by [email protected] View Post
    Make sure you have shims on hand for alignment.
    Surely you only need shims if you want to increase the camber angle over the maximum permitted with stock suspension arms.
    Maintained by RE Performance.
    Hidden Content
    Senior Member R8MYRWS's Avatar
    Nov 2017
    Calgary
    Re: Alignment
    Thanks for the responses all. I must say the tires have not changed pressure from when it was tracking true. But I will check them with a proper good quality gauge. Then report back. So now I will ask the Sales Manager at my dealer where the R8 guys go. Also mine does not have mag ride as it is a Canadian RWS. Adjustment is similar to the LMS cars. I only noticed this as a distinct handling difference from previous good speed runs on the same road. I will get it fixed prior to putting it to bed for winter around end of Oct.
    2018 R8 RWS, White, Sport Seats, Rear wheel drive #895/999
  4. Remove Advertisements
