Alignment
Results 1 to 10 of 12
Thread: Alignment
    Senior Member R8MYRWS's Avatar
    Nov 2017
    Calgary
    Alignment
    Folks, I was out today with a bunch of 15 cars or so and at around 227k on an undulating road the car felt downright unsafe. Weaving from side to side on road deformaties whereas it did not before. Now the Calgary area has $hitty roads and they call themselves a world class city and I have hit some huge holes and bumps. So the question is - do I start at the dealer or go direct to some reputable alignment center? What does everyone else do? Advice appreciated please.
    2018 R8 RWS, White, Sport Seats, Rear wheel drive #895/999
    Mar 2012
    PA
    Re: Alignment
    First place to start, is probably your tire pressures. Mine felt this way when I picked it up and I noticed the pressures were around 49-51lbs! Way too high. Lowered to about 38 and the car feels solid.
    2017 Ibis White Spyder - Black with red contrast stitching and carbon.
    Aug 2016
    South Wales. UK
    Re: Alignment
    Assuming your tyres are worn evenly and as suggested above, the pressures are correct, then an alignment check at a good independent is the next step.
    Maintained by RE Performance.
    Hidden Content
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Re: Alignment
    Agree with Trev on the subject.
    Senior Member Genesis7's Avatar
    May 2017
    Florida
    Re: Alignment
    Go indi try avoid stealer. Any one knows if is good to get alignment once a year or only when you feel the car is pulling?
  8. #6
    Jun 2019
    Bergen County, NJ
    Doesn't necessarily sound like the alignment to me. If you're tracking straight and your tire wear is good (even), I'd guess bushings are your culprit. Basically, you want to have the shop to look for excess play anywhere in the steering and suspension.
    2017 Audi R8 v10 | Mythos Black Metallic
    2016 Shelby GT350 | Magnetic Gray
  9. #7
    Senior Member ajsherrill's Avatar
    Jun 2016
    Burleson, TX
    Re: Alignment
    Is the road you were on grooved? I have had the same experience and thought it was my car. Turned out that the smallest grooves in the road made it feel loose like it was weaving.
  10. #8
    May 2019
    Madison, WI
    Re: Alignment
    Check for leaking Mag Ride Shocks...you may have lost a shock or two...especially since it seems like a new problem. On an undulating road.
  11. #9
    May 2017
    Florida
    Re: Alignment
    Also check if you had some extra glasses of wine as well...
  12. #10
    Senior Member Shawn@PacificGerman's Avatar
    Dec 2013
    Mission Viejo
    Re: Alignment
    Make sure you have shims on hand for alignment.
    2019 RS 5 Mexico Blue / VF, ABT, Kline, Brembo, HRE
    2017 R8 VF800 Supercharged / Dynamite Red / Audi Sport, ABT, KW, Tubi...
    2016 911 Turbo S / Boring White / GIAC, Tial, Tubi, Kline, Wagner, Techart, Champion
    2014 R8 V8 VF550 Supercharged / Samoa Orange
    2012 R8 V10 / Sepang Blue
    1989 964 C4 / Black for now-
    President, Pacific German Inc.
    Hidden Content
    Hidden Content
