Wtb: Pcm/ecu 2012 v10
Results 1 to 6 of 6
Thread: Wtb: Pcm/ecu 2012 v10
    Senior Member TheCzarofMexico's Avatar
    Oct 2016
    Houston, TX
    Let me know if you’ve got one.
    Bill Winters - 2012 V10|R-Tronic|Cactus green w/ carbon blades|CCB|Forgeline VX3C's & R888's|LPF Twin turbo kit tuned by Eurocharged: 753/531 @ 1/2 bar
    Supporting Vendor
    Jun 2016
    Worldwide
    Re: Wtb: Pcm/ecu 2012 v10
    These are VIN specific and injector dependent. What is your VIN?
    These also need to be coded to the instrument cluster.
    CFI
    CFI is offline
    Oct 2017
    LA
    i have a few laying around. need to know the hardware number on your existing ecu.
    Oct 2016
    Houston, TX
    That might help..
    CFI
    CFI is offline
    Oct 2017
    LA
    i only have hardware 004 and 007. through the dealer you can only go up in hardware number not back down. you can likely clone the stock ecu and make one work if you are having a private party do the ecu change.
  8. #6
    Oct 2016
    Houston, TX
    Tuner is saying he can clone any compatible ECU/PCM. Any 420910552Q (420 910 552 Q) should work.
  9. Remove Advertisements
