Pot Hole and Shocks
Results 1 to 5 of 5
Thread: Pot Hole and Shocks
    Member Derrick777's Avatar
    Mar 2012
    Hamilton, Canada
    Pot Hole and Shocks
    Just came back from a nice ride came off highway and WHACK! Sound like the front right then about 20 seconds later a warning about a shock showed up on dash but couldn't read if fast enough and now a suspension rattle. Steering straight still seems alright, pulled right front wheel off but don't see anything obvious so maybe the rear? With the dash warning sounds like it's an internal issue with shock? which ever one it maybe... Any suggestions? Thanks
    Mar 2012
    Hamilton, Canada
    Re: Pot Hole and Shocks
    1 Fault Found:
    00143 - Front Right Dampening Adjustment Valve (N337)
    011 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 36577 km
    Time Indication: 0
    Date: 2016.05.12
    Time: 19:55:08
    Freeze Frame:
    Voltage: 13.92 V
    Speed: 2.6 km/h
    Voltage: 4.95 V
    Bin. Bits: 00000001
    Bin. Bits: 00010000
    Ohms: 0.9
    Resistance: 390.15 ohm
    Clear code went about 50 ft light came on cannot turn on sport suspension, no rattles suspension looks ok. Did the VCDS to test electrical signal for shock check ok then after test drive showed error. Ran a comparison to left front shock feed back showed what wasn't happening. Another fault code said there was a short.
    Address 14: Susp. Elect. (420 910 376 )
    20:12:06
    0.186 A Valve Current Front Left
    3.9 % Pulse Width Front Left
    0.000 A Valve Current Front Right
    0.0 % Pulse Width Front Right
    next thing was to check wiring harness that maybe pinched or disconnected can't see much need to dig remove trunk covers but is it a internal issue? Can I turn the mag ride system off through coding? I can live with that until a get a new air ride setup...
    Member Eagarcia08's Avatar
    May 2017
    Baltimore, MD
    Did you ever figure this out? I have this fault as well.
    Mar 2012
    Hamilton, Canada
    I ended up replaceing all the shocks it was quite a while ago with some used ones might have been from a member from this site. I believe the shock in question was damaged internally and probably from lack of fluid as i had a couple of them leaking. I would hear thump or bottom out when i hit a good bump.
    Replacement shocks fixed all issues and improved handleing all around.
    A year after that i went to air ride suspension
    https://www.airliftperformance.com/v...-r8-2008-2015/
    May 2017
    Baltimore, MD
    Thanks for reply! Was hoping open circuit just meant a loose connection. Did you end up selling your mag struts?
    2012 V10 Spyder. Black w/ red. 6 spd MT. Enhanced leather. Illuminated Door Sills. HRE P40SC Brushed Red. Reid intake + K&N. VFE tune. Rev9 exhaust.
  8. Remove Advertisements
  1. Need New shocks
    By taxdr1965 in forum General Discussion
    Last Post: 03-03-2016, 08:10 PM
  2. Replies: 2
    Last Post: 11-27-2015, 11:10 PM
  3. Door key hole covers?
    By JGMACHINE in forum General Discussion
    Last Post: 04-15-2015, 07:21 AM
  4. Pot holes in Manhattan!!!
    By BLK CROC in forum General Discussion
    Last Post: 03-27-2015, 11:58 AM
  5. Shocks
    By prettibwoy in forum General Discussion
    Last Post: 04-18-2012, 05:23 PM
