Cracking sound when turning?
Results 1 to 10 of 18
Thread: Cracking sound when turning?
    Member Cires's Avatar
    Sep 2011
    Milwaukee, WI
    Hello all,
    Recently I've noticed what can only be described as a constant cracking sound when turning the wheels at low speeds on my 2010 R8 V10. It seems to be coming from the driver's side front wheel area. It sounds worse when I turn to the right, but it is there if I turn to the left as well. Does anybody have an idea what this might be?
    This may be unrelated, but I've also noticed a "sticky" noise coming from my tires at higher speeds, almost as if glue were stuck to them.
    While I haven't yet physically checked, my car should have the structural reinforcement plates since it was completed in mid December 2009.
    This is very different from the quattro "judder" that is common on R8s as well.
    Please turn your volume up - cracking from 4 seconds onwards.
    Oct 2006
    CT, USA
    Re: Cracking sound when turning?
    Yes, it doesn't sound like the common judder that occurs with slow speed turning - no "cracking" there, for sure.
    Have you inspected the suspension?
    -- Other Vehicles --
    2017 BMW 650xi Gran Coupe
    2012 Audi Q5
    Hidden Content
    Supporting Vendor ULTIMATEPD's Avatar
    Oct 2014
    Houston, TX
    CV joint??
    VAG COM Service in Houston - PM me
    OEM Clutch kits, Pedalbox, TCU tunes, Exhaust systems, OEM Genuine Parts
    Carbon Fiber accessories.
    Hidden Content
    Hidden Content Hidden Content
    IG shardul_amg
    Hidden Content
    Sep 2011
    Milwaukee, WI
    Here's the video as promised (cracking from 4 seconds onwards):
    In the video, it comes across more as clicking - in person it sounds like something is cracking apart.
    Sep 2011
    Milwaukee, WI
    Quote Originally Posted by ezmaass View Post
    I haven't had a chance to yet - I was originally thinking CV joint as ULTIMATEPD suggested but I'm not sure it would sound quite like this.
  8. #6
    Oct 2014
    Houston, TX
    A bad CV joint would produce a ticking / knocking sound
    Hidden Content
    IG shardul_amg
    Hidden Content
  9. #7
    May 2017
    Italy
    Lift the car and check. It might be a plastic broken piece somewhere near the wheel area
  10. #8
    Sep 2011
    Milwaukee, WI
    Quote Originally Posted by ingsteve View Post
    Let's hope so, otherwise I'm guessing it's going to be expensive.
  11. #9
    May 2017
    Italy
    No...either cv or something loose...otherwise you cannot drive safetly
  12. #10
    Oct 2014
    Houston, TX
    There are a lot of used axles for sale on ebay. I sold mine to someone who had failed CV joints.
    Hidden Content
    IG shardul_amg
    Hidden Content
  1. Clicking/ticking sound when turning
    By brn8 in forum Maintenance and Service
    Last Post: 08-21-2017, 10:01 AM
  2. Turning off footwell lights
    By ftdoan in forum General Discussion
    Last Post: 01-28-2016, 08:53 PM
  3. Strange sound under heavy turning
    By islandtrader in forum General Discussion
    Last Post: 01-19-2014, 10:10 PM
  4. Should P Zero Side Walls Be Cracking After 3 Months?
    By mountainreef in forum Wheel and Tire Discussion
    Last Post: 06-09-2013, 01:01 PM
  5. The rubbing feeling when turning.
    By EdwardR8 in forum Wheel and Tire Discussion
    Last Post: 09-26-2008, 09:29 AM
