Magnetic Ride Repaired - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
Thread: Magnetic Ride Repaired
  1. #11
    Apr 2016
    Runcorn, Merseyside, UK
    Re: Magnetic Ride Repaired
    Hi all,
    Long time lurker - first time poster!
    I have been weighing up the options too, and I'm going to send mine to Nagengast. However, I'm going to take the shocks off myself, package them up and deal directly with them. This saves you about £600 (Nagengast charge £780 per pair, plus £25 return postage), as long as you have the space to lay the car up. 3 days to post, 5-7 days for the work, 3 days return post so looking at 2 weeks in total.
    Will update after the process, cheers
    Apr 2018
    Yorkshire, UK.
    Will be interested to see how you get on with the whole process. Be good to know how easy it is or not to get the shocks off. I think the fronts require the trunk side lining to be removed. Fair bit to be saved in doing the removal and refit yourself though. Maybe start your own thread.
  4. #13
    Aug 2016
    South Wales. UK
    Sounds like a good option. Money and time saving and you get to keep the magrides.
    Maintained by RE Performance.
    Hidden Content
    Oct 2018
    Just bought a complete set of used Magrides, two fronts bone dry, two rears have misting on and were an advisory on MOT for £400. Mine are all currently OK so don't need them now, but will send the rears for repair, keeping a full 'good' set in reserve. Then will just swap them as an when they are needed, as I am sure they will. Hopefully, keeping the car on the road.
  7. #15
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Quote Originally Posted by pantera6 View Post
    Same plan as me, they're so cheap on ebay it's silly not to do this.
  8. #16
    Mar 2019
    Greater Seattle Area
    I'm going down that road myself and have started the process. I have a thread in the maintenance and service section of the forum. I will be interested to hear your experiences and any advice and counsel.
  9. #17
    Mar 2015
    ECS list this tool for the rear shocks, I haven't read the remove/install procedure so don't know what it does!!!!
    https://www.ecstuning.com/b-genuine-...ol/t40177~oev/
  10. #18
    Apr 2017
    Oahu
    I could be wrong, but that appears to be a tool that holds the strut rod to keep it from spinning while you remove the top strut nut.
  11. #19
    Mar 2015
    Quote Originally Posted by hamannperformance View Post
    You could be right too, thanks. I'll find out when I come to change mine, hopefully not in the near future!
  12. #20
    Jan 2018
    Sarasota, FL
    Look forward to the updates as I plan to keep a spare set on hand. I'm looking for a used set right now to send off for refurbishment.
  1. Ride quality on non-magnetic ride R8?
    By IS2000 in forum General Discussion
    Last Post: 09-01-2016, 07:03 AM
  2. Magnetic ride, the difference compared with stock ride ?
    By Mavster in forum General Discussion
    Last Post: 06-27-2016, 10:16 AM
  3. Would anyone buy a Cat D (minor damage) car (repaired)
    By andyhofer in forum General Discussion
    Last Post: 11-23-2009, 01:14 PM
  4. Replies: 6
    Last Post: 08-27-2008, 05:59 AM
  5. Magnetic ride ... STD or not?
    By Guilty in forum Wheel and Tire Discussion
    Last Post: 03-03-2007, 01:02 PM
