Great charger connection
Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 50
Thread: Great charger connection
    Senior Member CharleyH's Avatar
    Sep 2017
    Orange County , CA
    I recently got my first battery "maintainer / charger". It is a CTEK MXS 5.0 and works great so far. But, I wanted to find an easier way to hook it up. I know that there are several ways to make a connection inside the frunk, but I really didn't want to have to open my frunk every time I wanted to hook up the charger. So after doing a little research I found a really cool magnetic connection from a company called MagCode. In addition to being a simple magnetic connection, there is only 12 volt power at the connection point when the magnet is in place. So that means it doesn't need to have a cover because there is no power unless it is connected to the charger. I wanted to find a place at the front of the car that was easy to access and would be easy to return to stock if I ever wanted to. What I decided to do is mount it to one of the blanks that is used for the headlight cleaners. I am very happy with the results. It is very easy to use and if I ever forgot it was connected and pulled away the magnet would just pull loose and wouldn't cause any issues. I have to admit that I was a little concerned that it wold be visible and disrupt the aesthetics of the car, but when you are looking at the car it really isn't noticeable. If you know what to look for you can see it, but 99% of people will never notice it.
    Here are a couple of pictures.
    Charley
    Nov 2017
    LAX
    Re: Great charger connection
    Thats actually pretty cool and I'd like to try something like that out. Sent you a DM
    Senior Member HowieR8's Avatar
    May 2013
    Asia
    Nice mod installed in a convenient location. Did you have to remove the bumper for this install? Any drilling to run the wires? Thanks.
    Hidden Content
    Audi R8 V10 S-Tronic - Brilliant Red - Fire Red PPF -
    SprintBooster - Clearplex - Android AV - Michelin PS4S.
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    https://www.ebay.co.uk/itm/12-Volt-D...-/231148212430
    £31.98 on ebay, might give this a try.
    Sep 2017
    Orange County , CA
    Quote Originally Posted by HowieR8 View Post
    No the bumper didn't have to come off and no drilling to run wires. Here are some more pictures:
    You need to take off the center and side trim panels in the frunk.
    Then run the wire from the battery to the headlight area. I started on the top and in the center, and then fed the wire to the battery area, and then to the light. I purchased an extension wire from CTEK that had plugs on both ends. I used the "bolt on" connection to the battery and plugged the extension wire into it and then cut the wire to length and added connectors on the MagCode side.
    Great charger connection-img_1578.jpgGreat charger connection-img_1580.jpgGreat charger connection-img_1573.jpg
  8. #6
    Sep 2017
    Orange County , CA
    Then I drilled out the "headlight washer blank" to hold the MagCode connector. This was the trickiest part because there isn't a lot of extra room to play with. I also had to trim down one of the plastic washers that came with the MagCode connector so that it would fit and provide enough clearance for the nut to fit.
    Great charger connection-img_1581.jpgGreat charger connection-img_1582.jpgGreat charger connection-img_1583.jpgGreat charger connection-img_1584.jpg
    The last step was to take the remaining wiring (with a CTEK plug on one side) and connect it to the MagCode connector.
    Charley
  9. #7
    Mar 2015
    Super job Charley, thanks for the information and the pictures.
  10. #8
    Jun 2018
    Northern NJ
    Quote Originally Posted by CharleyH View Post
    Charley
    Click image for larger version.
ID:	231936Click image for larger version.
    Once again, just goes to prove all superheroes don't wear capes!! Nice job!!
    2014 Audi R8 V10 6MT
    Suzuka Gray/Red
  11. #9
    Sep 2017
    Orange County , CA
    Thanks for all of the positive response. I am definitely enjoying this mod and highly recommend it.
    Charley
  12. #10
    May 2013
    Asia
    Appreciate the diy instructions Charley.
    Looks like a great mod for winter storage. Cheers.
    Hidden Content
  1. Battery problem or Poor Earth Connection/Starter Connection?
    By Ace in forum Maintenance and Service
    Last Post: 06-13-2013, 08:38 AM
  2. Aux Connection/Napster
    By R8ecosse in forum General Discussion
    Last Post: 05-13-2008, 12:44 PM
  3. AUX/ipod connection
    By JOHN.KUSTARD in forum General Discussion
    Last Post: 01-30-2008, 01:29 PM
  4. R8 MMI connection..
    By R8chris in forum General Discussion
    Last Post: 03-14-2007, 02:52 PM
  5. Car Connection R8 drive impression
    By Kreso in forum General Discussion
    Last Post: 01-31-2007, 07:06 PM
