Aftermarket Stereo installation HowTo
Page 1 of 8 1234 ... LastLast
Results 1 to 10 of 74
Thread: Aftermarket Stereo installation HowTo
    Junior Member ZaOs's Avatar
    Feb 2019
    NJ
    I know many of us wanting to replace the crappy MMI in our R8s. However, one big challenge is the custom bezel. I started this thread to share my experiences installing an aftermarket stereo in my car. You need the following:
    1. Stereo. My unit is a Pioneer 8400NEX
    2. 3D Printed Bezel. I made one and published it on Thingiverse: Here
    3. Soldering equipment
    4. VW Stereo removal tools
    5. Sandpaper, vinylwrap, paint etc. Depending how you want to finish bezel
    6. Dremel (some cutting may be required)
    7. Standard tools
    8. Double sticky tape
    9. Patience
    10. 2 DIN Generic mounting kit
    11. Maestro Steering wheel interface
    12. VW wire harness
    13. FAKRA antenna converter
    14. Micro bypass circuit
    2011 Audi R8 Spyder
    2011 Audi Q7
    2005 Audi A8
    2005 Bentley Continental
    2003 Bentley Arnage
    1997 Lotus Esprit V8
    2013 BMW 640iX Convertible
    Feb 2019
    NJ
    Re: Aftermarket Stereo installation HowTo
    Phase 1:
    Since there is no simple inexpensive bezel out there I decided making my own 3D printed one:
    I am using Fusion360 to design the part. This is not an easy part to make, because of the complex curves it has. However. with a tracing tablet, it is easier
    2011 Audi R8 Spyder
    2011 Audi Q7
    2005 Audi A8
    2003 Bentley Arnage
    Feb 2019
    NJ
    After part is designed I am printing it on my Raise3D printer using ABS for material. You should not use PLA, because it does not well inside the car on hot summer days.
    Here is a link to the 3D printed build on Thingiverse
    2011 Audi R8 Spyder
    2011 Audi Q7
    2005 Audi A8
    2003 Bentley Arnage
    Feb 2019
    NJ
    It took a lot of tries before I got the part to fit right in the console. Below is some of the prototypes in the design process. Patience is of essence here, since one print takes more than 8 hours to complete....
    2011 Audi R8 Spyder
    2011 Audi Q7
    2005 Audi A8
    2003 Bentley Arnage
    Feb 2019
    NJ
    So, I finally made a part which fits snugly inside the console. I designed the part to fit with a generic 2 DIN mounting kit. Description below:
    Autostereo 180 x 103mm Universal Double DIN Installation Slot Metal Car Stereo Radio Mounting Frame 2DIN Universal Car Radio Adapter In-Dash Mounting Frame Complete Fitting Kit
    Available from Amazon
    Be careful with the frame. The plastic tabs on it are fragile.
    Below is a picture showing how the mounting kit adapts to one of my prototypes:
    2011 Audi R8 Spyder
    2011 Audi Q7
    2005 Audi A8
    2003 Bentley Arnage
  8. #6
    Feb 2019
    NJ
    Finally a finished part....
    Depending what you are looking for from the final part. You may be happy with the raw 3D printed look and just install it, or maybe paint/wrap/hydrodip the part. If you opt for further finishing you need to first sand and prime the bezel. Fortunately, ABS is very easy to sand and finish.
    I decided to wrap my bezel in a carbon fiber lookalike vinyl. It did turn out pretty good, but for best quality, probably hydro dipping is the best way to go...
    Attachment 233762
    Attachment 233764
    Attachment 233766
    Attachment 233768
    Not too bad for a first timer wrapping something
    Attached Thumbnails Attached Thumbnails Aftermarket Stereo installation HowTo-_dsc8317.jpg   Aftermarket Stereo installation HowTo-_dsc8328.jpg   Aftermarket Stereo installation HowTo-_dsc8329.jpg   Aftermarket Stereo installation HowTo-_dsc8330.jpg
    2011 Audi R8 Spyder
    2011 Audi Q7
    2005 Audi A8
    2003 Bentley Arnage
  9. #7
    Feb 2019
    NJ
    Phase 2:
    Part is done and it is time to start installing the new MMI. I did purchase a Pioneer 8400NEX to fit in my car:
    You also need a MMI adapter to retain steering wheel controls and features from the original MMI. I Went ahead with purchasing a Maestro ADS MRR from idatalink for my Audi R8:
    Then you need a wire harness to connect everything to. Idatalink provides harnesses to fit the Audi R8 together with the Pioneer 8400NEX.
    Description: Maestro HRN-RR-VW1 Plug and Play T-Harness for VW1 Vehicles
    You also need a FAKRA converter for your FM/AM radio antenna into the Piioneer unit:
    Description:
    Generic TWIN FAKRA Two Way TO SINGLE DIN CAR DVD Head Unit RADIO AERIAL Antenna ADAPTOR Cable for AUDI VW SKODA BMW
    If you want to watch videos while driving, you have to install a parking brake bypass. It is illegal in some places installing this, but?
    Description:
    MicroBypass ALL AVH-X Video In Motion Interface for Select Pioneer Receivers
    2011 Audi R8 Spyder
    2011 Audi Q7
    2005 Audi A8
    2003 Bentley Arnage
  10. #8
    Aug 2016
    South Wales. UK
    Great post. Thanks for taking the time to share.
    Maintained by RE Performance.
    Hidden Content
  11. #9
    Jan 2018
    Dallas, Texas
    Nice job, thanks for sharing!
  12. #10
    Jan 2018
    Sarasota, FL
    Thank you for taking the time to share this . Very good post.
  1. Aftermarket stereo headunit
    By joo in forum General Discussion
    Last Post: 03-03-2019, 11:26 PM
  2. Aftermarket stereo installation bits
    By jakesmith in forum General Discussion
    Last Post: 10-21-2018, 03:46 PM
  3. Howto remove rear end on the Audi R8
    By NiceGuy in forum Exhaust Systems
    Last Post: 06-29-2016, 08:18 AM
  4. 2014 aftermarket stereo possible?
    By 2WheelsOrFour in forum General Discussion
    Last Post: 08-16-2015, 02:04 PM
  5. Got my R8!! though problem with stereo - volume up and down?
    By Gord59 in forum General Discussion
    Last Post: 04-01-2008, 12:50 AM
