question for the 1st gen guys
Results 1 to 10 of 13
Thread: question for the 1st gen guys
    Senior Member NTM09's Avatar
    Mar 2019
    Michigan
    Been having a hell of a frustrating time finding an aftermarket warranty. All their website reviews are great until you look at independent and BBB reviews plus the subjective terminologies in the contracts would make a lawyer cringe. That being said I figured I take another approach and look at the risk/reward ROI analysis.
    So the questions are.
    What work have you had done whither it was covered under a warranty or not and at what mileage?
    Regards and thanks
    Mike
    Jul 2014
    NJ
    First R8. Full mag ride replacement at 19k. Same for second R8. Both replaced with coilovers, cost 3k both times. Second had both ECUs fail at 18k miles and cost 5k total. Third R8 had AC fail at 13k miles and cost over 5k. All are gen 1 pre-facift. First 2 were V8s, third is a V10.
    Hidden Content
    2008 Ferrari 430
    1991 Ferrari 348
    1997 Ferrari 355
    2006 Porsche Cayman S
    1999 Porsche Boxster
    2006 Porsche 911 S
    2007 Aston Martin V8 Vantage S
    2008 Audi R8 V8 R-Tronic
    2012 Audi R8 V8 6-Speed
    2011 Audi R8 V10 Spyder
    2013 Audi A5
    2006 Lamborghini Gallardo
    1966 Pontiac GTO
    1966 Chevy Nova (Pro Street/Strip)
    1971 Pro Street Chevy Vega
    1931 Model A 5 Window Street Rod
    1977 GMC Jimmy High Sierra
    Senior Member ajsherrill's Avatar
    Jun 2016
    Burleson, TX
    Re: question for the 1st gen guys
    Fidelity Platinum Warranty. Replaced both front struts at 55k, replaced O2 sensors twice at 64k,replaced cam position sensors at 64k. So to date I have been very impressed with this warranty.
    AJ
    Jun 2016
    Burleson, TX
    dertizjos,
    How did you know your ECU's failed? I have a check engine light that no matter what I try will not go off. I have been told by 2x different mechanics it could be bad ECU's.
    How did you prove and get them replaced under warranty? Thanks.
    AJ
    Jun 2016
    Burleson, TX
    NTM09,
    I have a 2009 R8V8..
  8. #6
    Jun 2017
    Orange County California
    Poster on another thread mentioned that new Fidelity warranty policies specifically exclude all shocks/struts. Anyone looking to buy Fidelity warranty may want to confirm this.
  9. #7
    Mar 2019
    Michigan
    Quote Originally Posted by OC R8 View Post
    I have a call into them now, I will confirm and post
  10. #8
    Senior Member WinterRunner's Avatar
    Jul 2015
    USA
    [email protected]
    Contact him for a Fidelity warranty. I had a V8 for 3 years, had mag ride replaced twice, drivers door lock replaced once, and rear taillight LED burned out, also replaced. 100$ deductible
    Whoever said Fidelity doesn't cover the mag ride is wrong, as it does. You have to claim them as magnetic struts, not shocks.
    I recently purchased a Platinum 10 year/ 100K warranty from Neil Brenner for 4117$, with 100$ deductible.
    Buy the Fidelity warranty.....
    Current: 12' R8 CF/Daytona V10 6MT
    ~VF/Hex tune~Avior Non-res~Reid intake tubes~10mm Spulen spacers~CF S-wheel~
    ~OEM euro side mirrors~Blendmount/iXc~Xpel'd~Gated 6MT~No questions asked~
    Past:
    09' Daytona/CF R8 V8 6MT
    08' Daytona/Ti RS4 (dearly missed)
    05.5' Dolphin S4
  11. #9
    Mar 2014
    wa
    warranty: national
    items repaired: door lock actuator, window regulator, gears that moves hvac flaps, hvac control module, replace oil pump drive shaft o-rings, updated ecu due to epc light, gear box sensor
    i asked about extending the national warranty and was told they no longer cover R8s
  12. #10
    Jul 2014
    NJ
    AJ,
    Kept getting CEL and eventually car wouldn't start. End result, two bad ECUs. The dealer tool care of the cost since it started happening the day after I bought it.
    ECUs are not cheap but if that turns out to be you issue, you can find them used.
    Were yours ever opened for a tune? This seems to be the biggest reason they fail. Once the seal is broken water causes the damage. At least that is what I was told.
    Hidden Content
    2008 Ferrari 430
    1991 Ferrari 348
    1997 Ferrari 355
    2006 Porsche 911 S
    2013 Audi A5
    1966 Pontiac GTO
  1. 2nd Gen Shock absorbers for 1st Gen?
    By DavidK84 in forum General Discussion
    Last Post: 06-15-2018, 06:26 AM
  2. Gen 1 vs. Gen 1 facelift vs. Gen 2 vs. Gen 2 RWD
    By chen in forum General Discussion
    Last Post: 04-16-2018, 07:39 PM
  3. 2nd Gen wheels on 1st Gen
    By rishi in forum Wheel and Tire Discussion
    Last Post: 01-27-2018, 07:30 AM
  4. Does 1st Gen facelift exhaust fit 1st Gen???
    By R8evo in forum Exhaust Systems
    Last Post: 07-30-2017, 10:17 AM
  5. R-tronic downshift to 1st gear OK? Question ...
    By SoCalR8V10 in forum General Discussion
    Last Post: 03-08-2012, 04:33 AM
