Brake fluid reservoir access - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Brake fluid reservoir access
  1. #11
    Senior Member aquarianuw's Avatar
    Oct 2012
    Greater Seattle Area
    Re: Brake fluid reservoir access
    Did soak some WD40 but that may not be enough. I ordered 2 more universal wiper pullers (one appears to be knock off of T10369 that Audi uses) and hopefully that will do the trick.
    Looks like I will be putting some anti seize before installing the wipers back...
    Quote Originally Posted by old phart View Post
    Just changed batteries and used the tool you show on the right for my wipers. On both sides it was very tight and made a very loud pop when it finally released. Thought I'd cracked the windshield. Have you tried spraying with penetrating oil and letting set for a bit? Coated mine with a little lube when I put them back on.
    2012 Audi R8 V10 - Titanium package - TCU tuned - Kline exhaust
    Oct 2012
    Thanks. I will keep you guys posted with the final result. Now I am debating whether to secure the piece with just velcro or plastic fasteners.
    Quote Originally Posted by tommyr8 View Post
    looks good and the factory should have made cover
    Quote Originally Posted by CharlieNJ View Post
    Being that I had a hole cut in my Frunk to access the cover, I like your look better.
    Quote Originally Posted by kiryu View Post
    wow, very well done
  4. #13
    Oct 2012
    Got another set of of wiper pullers and it worked perfectly along with some penetrating oil like Knocker Loose. I highly recommend those non adjustable pullers as they work way better and will cause much less damage to the wiper arms. The hole was cut out with a jigsaw.
    Junior Member Dgcompany's Avatar
    Jul 2017
    Chicago
    If you're still trying to remove the wiper arm, try folding up the wiper arm while tightening the puller tool. Mine wouldn't move unless I bent up the wiper arm. It's on there tight, but it will release.
  7. #15
    Senior Member HowieR8's Avatar
    May 2013
    Asia
    Good job with the mod Nelson. Very clean install.
    Hidden Content
    Audi R8 V10 S-Tronic - Brilliant Red - Fire Red PPF -
    SprintBooster - Clearplex - Android AV - Michelin PS4S.
  8. #16
    Aug 2016
    South Wales. UK
    Very neat job. You could be forgiven for thing it was OE if you didn't know differently.
    Maintained by RE Performance.
    Hidden Content
  9. Remove Advertisements
  1. Accessing Brake Fluid Reservoir
    Last Post: 05-27-2019, 05:48 PM
  2. access port for brake fluid reservoir
    By willyjp in forum Maintenance and Service
    Last Post: 04-25-2019, 09:04 PM
  3. Brake fluid reservoir access
    By Larry in forum General Discussion
    Last Post: 08-31-2017, 01:40 PM
  4. Replies: 14
    Last Post: 10-18-2009, 05:12 PM
  5. Brake reservoir access
    By 08R8 in forum General Discussion
    Last Post: 08-22-2008, 11:41 PM
