Creaking/cracking noise - Wheel bearing or CV joint?
Results 1 to 10 of 11
Thread: Creaking/cracking noise - Wheel bearing or CV joint?
    Sep 2015
    Aberdeen
    Creaking/cracking from drivers side wheel has been getting worse, here's a video driving on full lock.
    https://youtu.be/Iie_FGvthqU
    It's ok turning right, the noise only starts about 80% from full lock when when turning left, getting worse to full lock.
    Thinking it's either the wheel bearing or CV joint?
    It's a 2015 Gen 1 V10 Plus, only 23k miles, so not really expecting this, although the car has been faultless in the 4 years I've had it.
    Mar 2019
    Re: Creaking/cracking noise - Wheel bearing or CV joint?
    Do you have any video of interior sound?
    Junior Member Dgcompany's Avatar
    Jul 2017
    Chicago
    It seems to be consistent with the wheel rotation, so it might be wheel bearings or something associated with wheel rotation.
    Jul 2017
    Chicago
    ...usually the CV joint will make noise no matter which way the wheel was turned. I'd do CV and bearings all at once because the CV for our cars are inexpensive.
    Sep 2015
    Aberdeen
    Quote Originally Posted by extrablack View Post
    There isn't any additional noise from the inside, just what you can hear on the outside that filters into the cabin, if that makes sense.
  8. #6
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Have you eliminated any noise from a loose wheel arch liner? similar sound came from this on my wife's Q3.
  9. #7
    Member Wanderingmind83's Avatar
    Feb 2019
    This is strange! I was just about to post with a similar thing, and saw yours!
    So I have a very similar sound coming from mine, but it's there when driving in a straight line and it's behind me I think - drivers side real wheel area.
    It's quite a similar sound and I can hear it on the inside of the car.... HOWEVER it only started after driving for 15 minutes or so through quite lumpy bumpy city roads. After getting on some fast road and accelerating hard / driving at fast speed, it went away.
    It's done this twice now... sound not there, drive on bumpy roads at slow speed, sound starts... get it onto fast roads and accelerate hard, sound goes away again!!
    Really weird!
    It makes me think something comes loose and the G force of the car accelrating or perhaps wind resistance moves it back into place.
    Could this be an arch liner? Or any other ideas what could be initiated and relieved in the same way?
    Really hope it's not bearings! Can it be a CV joint if it's on the rear / do thy have CV joints on the rear wheels?
  10. #8
    Sep 2015
    Aberdeen
    So thought I would kinda finish off this thread as i jacked the car up on stands last weekend, removed all the wheels and tried to find the source of the noise with the hubs spinning... nothing, so put the wheels back on and yep, the noise has completely disappeared!
  11. #9
    Mar 2015
    Sounds like you've now got the wheels fully centered on the hubs and bottomed out without any gap, cheap fix.
  12. #10
    Feb 2019
    good to know you have got this fixed.
    With the sound in my car it also didn't come back.. I don't think it was anything wheel related although the sound was very similar.
    I went all around the car, using sticky felt and put bits in between any gaps on the interior that move, and also in between the rear small window and plastic bit (between the side blade and the window) basically looking for anything that creaks... so far so good sounding like a new car again, which makes me very happy.
  1. Creaking/cracking noise - Wheel bearing or CV joint?
    By Guffy in forum General Discussion
    Last Post: 05-19-2019, 07:51 AM
  2. Creaking noise, front end
    By low2groiund in forum Maintenance and Service
    Last Post: 08-05-2018, 12:23 AM
  3. Recommended check/tightening of AC coolant gas pipe joint
    By M3R8 in forum Maintenance and Service
    Last Post: 06-28-2016, 03:30 AM
  4. Clutch Bearing Noise?
    Last Post: 11-26-2008, 03:00 AM
  5. Creaking noise from rear suspension?
    By swansailor in forum Wheel and Tire Discussion
    Last Post: 07-29-2008, 05:41 AM
