Electrical fault - won't start - relay info please? - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Electrical fault - won't start - relay info please?
  1. #11
    Aug 2016
    South Wales. UK
    Re: Electrical fault - won't start - relay info please?
    Difficult one. Clearly there shouldn't be any signs of discolouration to the relay pins so something is amiss. If it were me, I would replace the 'faulty' relay with new and monitor it regularly. If it shows the slightest signs of discolouring, you may possibly have a relay carrier or wiring fault.
    Maintained by RE Performance.
    Hidden Content
    Sep 2018
    Thanks... it's not a coincidence is it that the relay pins are burned and then when I remove it I get the intermittent fault 100% of the time
  4. #13
    Aug 2016
    South Wales. UK
    Unlikely I would have thought.
    Hidden Content
    Sep 2018
    Ricky just said to swap the relay, keep an eye on it, if the scorching comes back then we know which circuit has got high resistance on, making the relay overheat. I'm guessing it is an issue with the circuit as it's happened to 2 relays on that board. Can't see any evidence of a bad earth anywhere but I guess it could be anywhere on the circuit
  7. Remove Advertisements
  1. Replies: 8
    Last Post: 10-25-2016, 12:34 PM
  2. ESP Fault. Car Won't start and Engine Light Is On.
    By Tropicana50 in forum Maintenance and Service
    Last Post: 04-27-2013, 05:36 AM
  3. Passenger Door Fault? Central Locking Fault? Door Wont Unlock?
    By pullmr8 in forum Maintenance and Service
    Last Post: 11-28-2012, 04:00 PM
  4. PLEASE HELP. Navigation Fault code? Please enter PIN?
    By Toankie in forum Maintenance and Service
    Last Post: 11-08-2011, 03:14 PM
  5. Wipers - Relay sound
    By satmarshall in forum General Discussion
    Last Post: 05-22-2009, 01:57 PM
