Electrical fault - won't start - relay info please?
Results 1 to 10 of 14
Thread: Electrical fault - won't start - relay info please?
    Sep 2018
    A few times the car has said ESP Fault & Brakes when starting, but started anyway, Now it won't start at all and I get those 2 messages. It is a manual V8 BTW
    I have 12.16V on the battery according to my multimeter which should turn it over - the car hasn't been used for a week or so but that's usually OK. Got a good run 6 days ago - 2x 40 minute motorway / highway runs - I don't think it is the battery
    I saw on here someone suffered this & it was the 'main supply relay' that needed replacing - I am assuming that is on the main relay board in the assenger footwell
    Can anyone tell me which relay it is & what type I need to swap it for - as something to try before getting it trailered away
    I am hoping it isn't a bad ECU...
    Jul 2017
    Vancouver, Canada
    Re: Electrical fault - won't start - relay info please?
    I have not had this one yet, knock on wood
    but here are the wiring diagrams that might help
    https://www.dropbox.com/s/ziuzzvb93u...ation.pdf?dl=0
    https://www.dropbox.com/s/5h0j6p0vxn...tions.pdf?dl=0
    White 2010 R8 V10, R-Tronic, Michelin Pilot Sport 4S, Stasis exhaust
    Sep 2018
    The recovery guy got this off diagnostics
    He advised swapping main relay & going from there but he didn't have the correct type of relay on his van to test so I can try tomorrow morning
    I hope this rules out the actual ECU being faulty as that is expensive
    Sep 2018
    Sep 2018
  8. #6
    Senior Member Tweaky's Avatar
    Sep 2013
    Hampshire UK
    I recently had a similar situation with symptoms and diagnostic readings like these, which turned out to be an earth bonding wire where the nut had vibrated loose causing arcing. This plastic unit holds relays and is located behind the rear shelf panel.
    Electrical fault - won't start - relay info please?-1bd40323-a00e-43c6-b876-b3f382b740b1.jpg
    The replacement relay cradle was £20 plus an hours labour to fit.
    R8 V10 6MT shortens straights and straightens curves.
    Neidfaktor complete stitched leather interior.
    Audi OEM carbon parts:
    'exklusiv' rear diffuser|carbon front lip|carbon engine bay|
    Aftermarket carbon parts:
    Interior engine bay lid|illuminated outer sills|inner sills|door trims|trunk surround
    Other parts:
    stitched alcantara trunk|stitched steering wheel|embroidered logo alcantara mats|
    MMI 3G|phone cradle with SDS high|1Tb hard drive|Kufatec TV|interior light and switch upgrade.
  9. #7
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Quote Originally Posted by Tweaky View Post
    Click image for larger version.
    An interesting observation for potential future problems,
  10. #8
    Sep 2018
    It was all OK this morning after refitting the old relay. I bought a new relay anyway and replaced it due to low price & ease.
    Car is in the shop now for a new front lid
    When I get it back I'll get the rear bench off and check out that earthing point looks like an easy fix if that's it
  11. #9
    Sep 2018
    So this problem again... I think I have identified it as I can now replicate the fault at will but it is a weird one
    If I remove the fuel pump relay, the very top of 2 of the pins (close to the relay, not the tips), are a little discoloured & it has a very slight slight electrical burning whiff about it. With this relay removed, the fault (ESP Fault & Brakes, car not starting) occurs every time I turn ignition on.
    But now that I have ferreted about with it, the car is perfectly fine anyway, as though there was a loose connection or something
    I have tried swapping it with the other relay on the same tray & it seems to be working perfectly with both relays.
    So either the relay is on its way out & the discoloration on the pin and slight smell point to this - or there is a fault in the wiring to or around the relay - I've had a really good look and can't see anything though.
    All I can think of is to replace both relays (they are a very common VAG part for about $8 each) and see how it goes from there as I want to avoid spending on hours of diagnostics if possible and I have use of another car.
    Any thoughts appreciated!
  12. #10
    Sep 2018
    Singed relay terminals - this isn't normal is it!?
    Relay board - if I remove the one on the left completely the fault occurs 100% of the time.
    BEEP - ESP fault
    BEEP BEEP BEEP - Brakes
    If I replace the relay the fault completely disappears
    It's the one on the left. Removing the one on the right or swapping them makes no difference
    And every now and again I get the fault with the relay in place
  1. Replies: 8
    Last Post: 10-25-2016, 12:34 PM
  2. ESP Fault. Car Won't start and Engine Light Is On.
    By Tropicana50 in forum Maintenance and Service
    Last Post: 04-27-2013, 05:36 AM
  3. Passenger Door Fault? Central Locking Fault? Door Wont Unlock?
    By pullmr8 in forum Maintenance and Service
    Last Post: 11-28-2012, 04:00 PM
  4. PLEASE HELP. Navigation Fault code? Please enter PIN?
    By Toankie in forum Maintenance and Service
    Last Post: 11-08-2011, 03:14 PM
  5. Wipers - Relay sound
    By satmarshall in forum General Discussion
    Last Post: 05-22-2009, 01:57 PM
