Clutch Squeak
Results 1 to 9 of 9
Thread: Clutch Squeak
    Feb 2012
    Houston, TX
    Clutch Squeak
    Have experienced a clutch squeak on/off for a few months and now it is consistent. Occurs when depressing or releasing.
    2012 V10, 17k miles, original clutch
    Pedal is smooth, engagement feels normal, no other shifting issues.
    Thoughts/places to start investigating?
    Aug 2016
    South Wales. UK
    Re: Clutch Squeak
    Is the squeak from the pedal or the clutch area?
    Maintained by RE Performance.
    Hidden Content
    Feb 2012
    Houston, TX
    Re: Clutch Squeak
    I have not listened from near the pedal to isolate but it would appear to be from the pedal area or right above. At first I thought it was type of shoes but now it is any type.
    If it matters, this car does sit a fair amount for weeks or a month or so at times, so if anything were to dry out from lack of use (bushing, for example), that might be a contributing factor.
    Aug 2016
    South Wales. UK
    That was my line of thinking. You could try lubing the pedal pivot with some wd40 or similar and see if that has any effect
    Hidden Content
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Re: Clutch Squeak
    Quote Originally Posted by Trev450 View Post
    Always go for the simple fix first eh Trev? usually it works.
  8. #6
    Aug 2016
    South Wales. UK
    Re: Clutch Squeak
    Absolutely, Dave. Why make work for yourself?
    Hidden Content
  9. #7
    Feb 2012
    Houston, TX
    Re: Clutch Squeak
    Diagnosis from dealer so far is the master cylinder is the likely cause of the squeaky noise.
  10. #8
    Feb 2012
    Houston, TX
    Re: Clutch Squeak
    Car still at dealer and it may not be master cylinder at the moment. Where exactly are the points for lubrication? Before I took it there, I looked up above the pedal but there is a cover I believe so presume the portion of which you are speaking is up above that area near the bottom of the dashboard?
  11. #9
    Aug 2016
    South Wales. UK
    Re: Clutch Squeak
    I haven't accessed it myself but would imagine that there are some trim pieces under the dashboard as you suggest that would need removing to gain access to the pedals. Apart from a pivot point, the clutch pedal also has a spring bedind it. I would think that either of these has the potential to squeak if dry.
    Hidden Content
  1. new squeak noise when cold?
    By aquarianuw in forum General Discussion
    Last Post: 02-09-2014, 01:08 PM
  2. squeak coming from dashboad v10 s tronic
    By colsey in forum General Discussion
    Last Post: 10-16-2013, 02:59 PM
  3. squeak coming from dash on v10 plus
    By colsey in forum Appearance / Body Modifications
    Last Post: 10-12-2013, 03:36 PM
  4. An annoying squeak which isn't brake problem
    By Condor in forum Maintenance and Service
    Last Post: 07-20-2013, 11:41 PM
  5. Suspension Squeak
    By Garyhun in forum Wheel and Tire Discussion
    Last Post: 08-20-2009, 08:32 AM
