HELP MY A/C DOESNT WORK on my V10
Results 1 to 10 of 20
Thread: HELP MY A/C DOESNT WORK on my V10
    Jun 2018
    Italy
    Hello today was very hot and while driving my R8 V10 year 2012 I start the A/C but no cold air the fan just blow warm air, now I have this car for 2 years and I never charged it as last year summer was working great as I have the VCDS how can I perform a test to see what the problem is? Or what she’ll I do to understand what is going on ?? Also if in need of recharge with gas how she’ll i tell the guy the right way tondo the charge ? I heard that all the humidity should be vacuumed out ,how ? Thank s for the help
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Re: HELP MY A/C DOESNT WORK on my V10
    What does the control switches do? are they functioning? warm air from all the vents?
    Dec 2017
    Florida
    My AC light wouldn’t come on dash panel, dealer diagnosed as some sort of valve in the system, I think the valve was $90, but with labor total bill was approx $550
    Senior Member GT#298's Avatar
    Mar 2018
    DFW
    I also had the failed pressure switch. It was the first repair I had to do on this car. Replacement switch was around $50, and $200 labor at my indi-shop. But then, at the end of last summer I was turning on the AC and heard something clatter. Not very loud, but just loud enough to make your wallet flinch. $5K for that one. Here's to hoping it's your pressure switch.
    You know. . .I learned something today.
    Be sure to use your AC often, and have it serviced fully every two years, whether it needs it or not. It seems that's the trick to longevity with these compressors.
    Senior Member aquarianuw's Avatar
    Oct 2012
    Greater Seattle Area
    Do you know what's involved with servicing the AC every 2 years?
    Quote Originally Posted by GT#298 View Post
    2012 Audi R8 V10 - Titanium package - TCU tuned - Kline exhaust
  8. #6
    Mar 2018
    DFW
    Quote Originally Posted by aquarianuw View Post
    Nope. . .except that it's good idea to "freshen" the fluids often because the lubricants break down from the heat. I read it on one of these forums a while back. An ounce of prevention...or a $5K+ cure.
  9. #7
    Aug 2016
    South Wales. UK
    I've recently had a similar problem with mine. The system had lost the gas and when tested a small hole was found in one of the condensers. After discussing it with Ricky, I elected to change them both as they were in a fairly poor condition from road debris hitting them.
    Maintained by RE Performance.
    Hidden Content
  10. #8
    Jun 2016
    Midlands, UK
    The condensers are an Audi A6 part so they're not funny money either. On my old car I had all the O rings changed as I saw a bit of evidence of fluorescent dye so it'd had a leak in a past life too.
    I wouldn't go forcing any system tests with VCDS until you've done a physical check and found any leaks. At least VCDS should be able to tell you if there's pressure showing in the system.
  11. #9
    Oct 2006
    CT, USA
    I rarely use my A/C. If it wasn't working, I may not know it for a long, long time. I know there have been tons of discussions on root cause analysis here (similar to those on mag ride shocks), but I'm not sure we ever had anything definitive. I've heard heat is a factor potentially more than utilization (too much or too little?). Haha.
    The way I look at it, if it breaks, I'll deal with it. I take care not to abuse anything, but unless we can get definitive evidence on a root cause, I feel like we may just start employing superstitious behavior after a while - soon we'll be flipping the vents open and closed 5 times for good luck before driving.
    -- Other Vehicles --
    2017 BMW 650xi Gran Coupe
    2012 Audi Q5
    Hidden Content
  12. #10
    Mar 2015
    You don't do this yet Ez !!!!!!!!!!!!!!
