Just had an oil change by the dealer.... - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Just had an oil change by the dealer....
  1. #21
    Senior Member aquarianuw's Avatar
    Oct 2012
    Greater Seattle Area
    Re: Just had an oil change by the dealer....
    3 N-013-806-3
    2 N-013-814-7
    Total 5 washers so it should have been correct.
    On the service invoice was there a charge for new crush washers for the drain plugs?
    2012 Audi R8 V10 - Titanium package - TCU tuned - Kline exhaust
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Quote Originally Posted by aquarianuw View Post
    3 N-013-806-3
    2 N-013-814-7
    Yes, at least this part's right.
  4. #23
    Oct 2012
    Quote Originally Posted by kiryu View Post
    i thought only r8 certified master tech are supposed to work on the car. If they pass this to some entry level mechanic for oil change he prob didnt know the car has 5 drain holes (cant remember how many it was..more than 3 for sure)
    Yeah it was indeed an R8 tech who worked on my car. Not sure what happened here...
    Oct 2012
    If I had a lift a home, I would definitely do the oil change myself....
    Quote Originally Posted by 2old4this View Post
    I think that would be a waste of your time. They’ll never admit they didn’t do a proper job, and since “the color of the oil” is not a good proof, you have no recourse.
    In the future, you may need their help fixing a more serious issue. So, I’d let it go...
    However, if you want to feel comfortable, spend another $160, buy new oil+filter+washers, and change the oil. That’s what I’d do...
  7. #25
    Nov 2018
    I know it is a pain if you don’t have a lift. You may want to take a look at QuickJack (ECS Tuning carries them at reasonable prices.) Also you may want to check shops around you. Where I live, there are shops that let you “rent” their lifts hourly on Sundays.
    I am attaching a picture of the oil color from my car (changed the oil something like 10 days ago...)
    Attached Thumbnails Attached Thumbnails Just had an oil change by the dealer....-d1094a2a-5ebf-4a33-b7b4-2ba848f7d614.jpeg
  8. #26
    Jan 2019
    if it isn't straight black or smells like gasoline it's probably newish oil. I think it's about a quart of oil that's left in there if it was overfilled I'm guess more then a quart of old oil
  9. #27
    Oct 2012
    Thanks for the photo. The color of your 10 day old oil appears to be slightly lighter than mine, perhaps very similar.
    Did you change the oil yourself? If so do you know how much old oil was collected?
  10. #28
    Nov 2018
    I did not measure what drained out :-(
    However, I've added about 8.5 liters and that was enough.
  11. #29
    Jun 2016
    Live Free or Die
    Quote Originally Posted by TurbousMaximus View Post
    I could be wrong, but it doesn’t look too bad. I think it only takes one cycle through the engine for the oil to look that way. The oil is never going to come out the same way it goes in, not matter how little you drive it. Just starting the car will cycle most of the oil. I wouldn’t be too worried about the color.
    This is accurate. It doesn't take many miles at all to make oil look "dirty". I'd be more concerned with overfilling than I would color.
  12. #30
    Oct 2012
    So according to this guy on youtube:
    https://www.youtube.com/watch?v=uRW26gg6HA8&t=491s
    There are 7 drain plugs instead of 5 that we know.
    However, based on this video, https://www.youtube.com/watch?v=ZO7r-huopOY&t=722s this guy only drained out from 5 and got about 9 liters of oil out.
