Is there a switched 15 amp fuse behind the seats?
Results 1 to 7 of 7
Thread: Is there a switched 15 amp fuse behind the seats?
    Senior Member aquarianuw's Avatar
    Oct 2012
    Greater Seattle Area
    Does anyone know if there is a switched empty 15 amp fuse behind the seats in the shelve? I would like to add an USB charging port (https://www.amazon.com/gp/product/B0...WM4PJ26Q&psc=1) inside the cubby. Thanks a lot!
    I would like to use https://www.amazon.com/10-Pack-Add-c...9313&s=gateway
    to get the power from an empty fuse in the rear if possible.
    2012 Audi R8 V10 - Titanium package - TCU tuned - Kline exhaust
    Apr 2017
    Groton
    Re: Is there a switched 15 amp fuse behind the seats?
    You definitely do an “add a fuse” from the fuse block under the passenger footwell... then just run the wire along the end of the center console to the cubby.. just loosen or remove the screws under the cubby to give you wiggle room!!
    Jan 2019
    You know you can swap that with the cigarette lighter...
    If not I would guess the light in the cubby can be spliced into or if you have a CD player it should have power.
    I added a usb by going to the fuse box running it up under the glove box and pulling out the knee pad on the passenger side up to the little shelf above the ac controls. The wire is easily accessible have just enough slack to keep the phone from flying away when I floor it but to be easy to use.
    Oct 2012
    All done! Regarding the cigarette lighter, my exhaust wireless controller is currently using it so I have to keep the cigarette lighter.
    I believe by going through the rear fuse box is definitely a lot easier than through the passenger side fuse box.
    The second photo shows the bluetooth to aux adapter hooked up so I can stream my spotify music (obviously no steering wheel control except the volume but that's fine with me).
    Jan 2019
    Quote Originally Posted by aquarianuw View Post
    Click image for larger version.
    Looks good
  8. #6
    Oct 2018
    I put in a new head unit and did away with my CD multi changer, I then put in a cubby box with the USB socket. I picked up my feed and earth from the multi changer wiring loom. Is there a switched 15 amp fuse behind the seats?-20190524_161825_1_1561699349898.jpg
  9. #7
    Oct 2012
    Quote Originally Posted by Barefoot View Post
    I put in a new head unit and did away with my CD multi changer, I then put in a cubby box with the USB socket. I picked up my feed and earth from the multi changer wiring loom. Click image for larger version.
    Nice. I thought about getting power from different wiring sources but didn't want to splice anything...
    Also, is the power source from the CD changer switched? The XM radio is constant on and I believe the CD changer has constant power too...
  10. Remove Advertisements
