Problems with VF750 Supercharger check engine codes and performance - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Problems with VF750 Supercharger check engine codes and performance
  1. #11
    Junior Member DrBeau's Avatar
    Mar 2017
    St. Albert
    Re: Problems with VF750 Supercharger check engine codes and performance
    Thanks for the reply.
    Member HowieR888's Avatar
    Jun 2019
    Install the Hitachi high flow fuel injectors that came with the VF kit and see if that fixes the problem.
    It comes with the Supercharger kit so why not try it? Good luck.
    Hidden Content
    Audi R8 V10 S-Tronic - Brilliant Red - Fire Red PPF -
    SprintBooster - Clearplex - Android AV - Michelin PS4S
  4. #13
    Senior Member CharlieNJ's Avatar
    May 2015
    NJ
    Usually when your shop does the install, they have to do a couple of pulls and record the data and send it to VF for Fine Tuning. I would assume that any tuning issues would have showed up then. Was this done or did they just do the hardware installation, download the standard VF tune and give you the car? I'd hope that your shop is ten steps ahead of most people here giving you suggestions, but it never hurts to ask questions. I'm in a Gen 1 and have absolutely no issues; even passed NJ inspection. Good Luck in getting it sorted out.
    2014 v10, S-Tronic, Phantom Black Pearl, GMG Racing CF Wing,
    PedalBox, Tubi Rumore Exhaust, VF750 SC
    2014 Audi Q5 TDI
    Previous:
    2005 Dodge Viper, SC
    1969 Pro Street Camaro BB 572ci
    1969 Alky Injected Camaro Race Car BB 522ci
    1971 Z28 original
    Mar 2017
    St. Albert
    Yes they did a pre and post install Dyno runs. On the Dyno hard runs are fine. I just have car at Audi now getting new plugs and coils. Hopefully this will solve all misfires. I spoke with Nik at VF and he says this year car doesn’t need the Hitachi high flow injectors. He wanted me to run some logs for certain things to test ignition, injectors, etc. But before I take it to California I thought I’d just change the plugs and coils.
  7. Remove Advertisements
