2010 V8 6MT stuck in 1st gear...thoughts ??
Results 1 to 10 of 18
Thread: 2010 V8 6MT stuck in 1st gear...thoughts ??
    Senior Member Hat Trick's Avatar
    Mar 2017
    Virginia
    3 miles away from home I pull away from a stop light and the car won't come out of 1st gear. Gear lever slides with no resistance into 2nd, 3rd gear when the clutch is engaged but the transmission is pulling in 1st only. I can't get the lever to slide into 4th, 5th or 6th. So I accelerate and coast, repeat, repeat. Make it home and put her nose first in the garage.
    This morning I pull out the airbox and complete a gear shift linkage adjustment. Does nothing.
    Put the gear lever in neutral...it drives forward. Put the lever in reverse...it drives forward.
    I'm at a loss. Problem is I can't even push it out the garage to get on a flatbed.
    Clutch has been rock solid. Not once has it slipped. No grinding on any gears either so I doubt it's a transmission problem.
    I've researched and have seen issues with this on the R-Tronics but not the MTs.
    Car has 75k miles and has been bullet proof during my ownership. No track time and although I drive her hard there's been no clutch burning launches or otherwise mistreatment of the car.
    Throw out bearing ? Slave Cylinder ??
    2010 Phantom Black Pearl. V8 6MTHidden Content
    Jan 2019
    Re: 2010 V8 6MT stuck in 1st gear...thoughts ??
    Have you checked the transmission fluid? Did you have any smells? If it leaked out a quart is way cheaper then going to the stealership. If you haven't pushed the car hard might be the throw out bearing leaking (pretty small seal) or the slave cylinder. I would go the route of checking the transmission fluid and filling it if it's low. The R tronics never had it on the service schedule to change the fluid. Its not that expensive to have the fluids changed so I'd look into it.
    Senior Member Nosferatu's Avatar
    Jul 2017
    Florida
    are we sure the shifter is physically attached still to the transmission linkage?
    2017 Audi R8 V10 Plus Ara Blue Crystal
    Larini Club Sport Exhaust
    10.8 @ 128 MPH (60' 1.68) - Stock
    10.6 @ 130 MPH (60' 1.66) - Exhaust+Pilot 4S Tires
    2018 Audi RS7 Performance
    Mythos Black
    Stock...for now. Hidden Content
    May 2014
    Manhattan
    Quote Originally Posted by Nosferatu View Post
    yeah this is what i was thinking, doesnt seem possible any other way to have a shifter moving and still be in 1st gear no...
    Jul 2019
    SoCal (Oak Hills)
    It sounds like you can push the clutch in and disengage the trans from the engine. If this is the case, then the issue would not be with the clutch master, slave, clutch or throw out bearing. From the symptoms, it sounds like either the shift cable or cables broke, the actual linkage brackets that the cables mount to on the trans have stripped the splines(not likely), broke a fork inside the trans(could be a possibility), but this would cause grinding when you tried to shift into other gears since it would want to be in 2 gears at the same time. The cables could have come off at the shifter as well. Would take a second person or a video camera, but you could move the shifter through the gears with the car off and the clutch in and see if the linkage is moving every time you shift gears. If something isn't moving, you can follow that path and find the issue. If everything is moving, you can disconnect the cables at the trans and see if you can physically move the linkage into a different gear or gears. Hopefully its just a cable end that came off at the shifter (since you mentioned doing the linkage adjustment) and not a fork or anything. Hope this helps.
  8. #6
    Mar 2017
    Virginia
    Grateful for everyone's replies thus far. It has been helpful.
    I took the cables off and was able to move the left linkage into neutral and can now push the car freely.
    While driving home, despite not being able to shift out of first, I could engage the clutch to drop revs and coast...then start over again. The clutch has plenty of tension, does not go soft and maintains its normal engagement point.
    I've been texting with an Audi Tech at the Richmond Dealer this weekend who has been awesome to work with ( thanks Brock !! ) and will have the car delivered to him this week.
    I've checked brake and transmission fluids this morning. Levels are normal and no apparent leaks.
  9. #7
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Have a look at these 2 drawings, they'll give you an overview of the systems and parts numbers (if you don't have these already).
    https://audi.7zap.com/en/rdw/audi+r8.../3/311-311085/
    https://audi.7zap.com/en/rdw/audi+r8.../7/711-711010/
    Suspicious that they list repair kits for 2 items !!!!
    7) 086 398 211 A repair kit for relay lever
    5) 086 398 211 C repair set for coupling rod
  10. #8
    Jul 2019
    SoCal (Oak Hills)
    Glad you were able to put it in neutral and at least get it rolling.
    The repair kits are just kits for parts that normally wear, like the plastic/nylon/delrin parts that wear from everyday use, along with the related hardware. Wouldn't be a bad time to change them out since it's going to be/already apart. Easy maint.
  11. #9
    Mar 2017
    Virginia
    Thanks JosB.
    Would also mention one night last week the RPM Gauge did not work on way to dinner. Has never happened before and the car ran perfectly. Upon restart, the tachometer worked normally and hasn't happened since.
    Not sure if this was onset to the current issue or was just an anomaly.
    Last night I reattached the gear cables and my Son took a video of the gear linkage set above the transmission while I sat in the car and rowed through the gears. First gear showed the only movement.
    I've got to believe this a gear cable / hardware issue now and not a trans/clutch problem. Will post up when we know more.
  12. #10
    Jul 2019
    SoCal (Oak Hills)
    Sounds like something broke in the shifter, or something wore out and fell off, but that is kinda far fetched considering the low miles on the car.
