Magnetic Ride: Clarification - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Magnetic Ride: Clarification
  1. #11
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Re: Magnetic Ride: Clarification
    Quote Originally Posted by Wanderingmind83 View Post
    That's exactly what I'd like to improve, certain kinds of corner I currently feel more comfortable doing in an E46 and I know that's not right!
    Sounds like PS4S is the next change then, what I have been experiencing is not to do with dampers which is very much a good thing
    In terms of tyre pressure I'm feeling like they are maybe too pumped at the moment, perhaps making it feel more sketchy cornering at speed.. It's strange it sometimes feels like the back end is lighter than the front even though the engine is back there..
    Once you've lost your confidence in a set of tyres it never comes back (ask any motorcyclist), a change to PS4S will restore your confidence after fitting/alignment and got the tyre pressure to your liking (recommended pressures seem very high).
    Senior Member NZV10's Avatar
    Mar 2017
    New Zealand
    But what I noticed was on this run the suspension was with sports mode off, but it had clearly tightened up due to the speed - this was working fine in some regards but obviously can't react well to uneven road, so there were times on that run where it felt suspension was actually reducing performance by changing.
    There seems to be common confusion about sports mode and suspension. There is no link at all between the two. Sports mode effects throttle response and gear changes only. The only thing that controls suspension settings is the suspension button, and the continuously variable element of mag ride itself.
    2010 R8 V10 Daytona Grey R-tronic
    2011 S5 V8 Quartz Grey Tiptronic, sports differential
  4. #13
    Senior Member Wanderingmind83's Avatar
    Feb 2019
    Quote Originally Posted by NZV10 View Post
    I have a manual...
    But when I press the mag ride button
    It says on the dash:
    'SPORTS MODE ON!'
    Press it again
    'SPORTS MODE OFF!''
    So I meant sports mode / mag ride settings not the other kind of sports mode..
    Sent from my STV100-4 using Tapatalk
    V8 | Stage 1 Remap | Daytona Grey Body & Blades | Manual 6 | Valved Capristo Exhaust | Extended Leather | B&O
    Bristol UK
    Oct 2006
    CT, USA
    I have a manual...
    'SPORTS MODE ON!'
    Press it again
    'SPORTS MODE OFF!''
    To be fair, Audi uses the term "Sport Mode" in various ways, themselves, throughout the manual. They do so in relation to three settings, in particular, all of which are independently activated.
    - Sport Mode (Transmission): For owners of R or S-Tronic transmissions, this is activated by pressing the "Sport" button on the transmission selector surround plate. It changes the way gears are held (auto mode), shift times, throttle response, rev-matching, and exhaust valves. Swansailor recently commented that he didn't believe the last two were affected on his 2008 R-Tronic; however, many of us, myself included, appear to have this behavior included. The manual makes no reference to them (that I can see), but they're easy enough to witness.
    - Sport Mode (ESC): Audi references an ESC-reduced mode (allowing for some wheel spin/slip) ALSO as Sport Mode, which is also required for launch control.
    - Sport Mode (Magnetic Ride): Audi refers to the stiffer magnetic ride setting as "Sport Mode" in the manual, as well.
    It would probably have made sense for Audi to get their nomenclature and terms straight. MOST members on this forum refer to Sport Mode when speaking about the transmission related settings (probably because the button is actually labelled "Sport"; however, the ESC and Magnetic Ride settings arguably use the same term... making it all very confusing.
    To be clear, however, these three systems, although called the same thing, each have independent buttons to activate them.
    -- Other Vehicles --
    2017 BMW 650xi Gran Coupe
    2012 Audi Q5
    Hidden Content
  7. #15
    Senior Member CharlieNJ's Avatar
    May 2015
    NJ
    I've had the car into the 150's at the track and do not remember the car feeling unstable. It was also probably at that speed for up to 15 seconds and not minutes, like you may have experienced on the highway. I've had both the stock Pirellis and Mich PS4S, which are on the car now. The Pirellis felt OK, but I do prefer the Mich handling in Wet or Dry situations.
    2014 v10, S-Tronic, Phantom Black Pearl, GMG Racing CF Wing,
    PedalBox, Tubi Rumore Exhaust, VF750 SC
    2014 Audi Q5 TDI
    Previous:
    2005 Dodge Viper, SC
    1969 Pro Street Camaro BB 572ci
    1969 Alky Injected Camaro Race Car BB 522ci
    1971 Z28 original
  8. #16
    Feb 2019
    Quote Originally Posted by CharlieNJ View Post
    I've had the car into the 150's at the track and do not remember the car feeling unstable. It was also probably at that speed for up to 15 seconds and not minutes, like you may have experienced on the highway..
    Exactly that, I hit 160 and stayed there for perhaps 4 seconds before backing off quickly. Every movement of the wheel is emphasised so much, it is not a speed I could confidently sustain for much longer. It's such a strange sensation coming back down to 110mph, it feels like you're going so slowly - really weird!
    That speed test was on a totally straight road, and actually, it wasn't on that run that it felt unstable.
    It's been on other runs let's say around 130mph but where there is a slow long bend in the road - as soon as the car starts to move away from wheels dead straight ahead, this is when it starts to feel a bit unstable and light on the road I have found.
    Bristol UK
  9. #17
    Senior Member ThunderDent's Avatar
    Jun 2018
    Quote Originally Posted by ezmaass View Post
    I have a manual...
    'SPORTS MODE ON!'
    Press it again
    'SPORTS MODE OFF!''
    It would probably have made sense for Audi to get their nomenclature and terms straight. [IMG class=inlineimg]https://www.r8talk.com/forums/images/smilies/smile.gif[/IMG] MOST members on this forum refer to Sport Mode when speaking about the transmission related settings (probably because the button is actually labelled "Sport"; however, the ESC and Magnetic Ride settings arguably use the same term... making it all very confusing. [IMG class=inlineimg]https://www.r8talk.com/forums/images/smilies/smile.gif[/IMG]
    I’m assuming for 6MT owners there’s no way to change throttle response since we don’t have a sport mode/transmission button. The other items are null for us obviously.
    I plan on putting a race chip on mine here soon for that actually!
  10. #18
    Jan 2019
    On a straight flat road is pilot sport 4s is ok but the random bump will make you back down. I went 170 for a stretch late at night in Houston till I backed off when the road got bumpy. I've never experienced the Pirelli's but I can speak about the Bridgestone RE's when warm and dry the grip seemed better in a turn, ride was definitely stiffer and way more fun when cold and dry letting the tail end out a little bit. Although dangerous as hell when any amount of wetness was involved. I got rid of them right before they needed to be replaced but one dangerous event is enough. PS4S is the best all around tire though. Just wish they had a stiffer side wall.
  11. Remove Advertisements
