Trunk Plastic cover how to remove it
Results 1 to 8 of 8
Thread: Trunk Plastic cover how to remove it
    Jun 2018
    Italy
    Hello
    I need to remove the trunk to change the battery I could easily remove the 3 plastic parts on both sides and front one but the one under the front glass is impossible to move out,i took off the wipes and the gas shock try hard to pull out but I’m worrying to brake something if someone can explain how to manovre it for taking out or if there screws under it ?
    Senior Member GT#298's Avatar
    Mar 2018
    DFW
    Re: Trunk Plastic cover how to remove it
    There are two bolts in the front that hold the tub down, but you have to remove that cowl piece first. It's held in place by a plastic lip that runs the full length of the windshield base. You'll want to go straight up with it very carefully to pop it loose.
    Sep 2018
    I just started in one corner of the windscreen and peeled it up using a plastic trim tool
    Obviously make sure all the screws are out!
    There are no screws beneath it holding it down or anything hidden
    Senior Member Wcclubchamp's Avatar
    May 2018
    I just completed the exact same. Another piece of advice. After installing the AGM battery it will need to be coded using the VCDS/VAGCOM software. As much as I enjoyed saving $700 with a DIY, it truly was a pain in the ass and also needed to be connected to VAGCOM to ensure the job was completed properly. I am not sure what the consequence of not coding after the install, but fortunately had a friend with the computer and software to connect and input the product info of the new battery.
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Quote Originally Posted by Wcclubchamp View Post
    It enters the power capabilities of the new battery into the power management system, this shuts down non-essentials when the battery voltage levels drop if it is discharging e.g. when parked a long time.
  8. #6
    May 2018
    Thanks Dave! Do you know if this is catastrophic if not done 100% properly post install? I attached a photo of the old battery with BEM/QR code and the new Varta OEM AGM battery ($258) to show how different they are than the old ones. To the OP make sure to get this done after install in the DIY project.
    Thankfully I am friends with my SA who informed me of this just in time as I was completing the install and putting the panels back onto the car. He helped connect to VAGCOM and entered the product code in and I HOPE it was done properly.
    I am amazed that when I purchased the battery from Parts At Audi, they made no mention of post installation coding with VAGCOM. Unreal.
  9. #7
    Mar 2018
    DFW
    I have VCDS and was prepared to do this after the swap, but I never had reason to. Everything worked fine right away, and all the dash lights went out after a short drive around the block and everything's been fine since then.
    FWIW, the replacement battery was a direct match to the old one.
  10. #8
    Mar 2015
    Not essential, I didn't bother as my new battery type isn't listed.
  11. Remove Advertisements
