Will Disconnecting Spoiler Throw a Code?
Results 1 to 8 of 8
Thread: Will Disconnecting Spoiler Throw a Code?
    Jun 2019
    I am going to install a spoiler on my 2014 R8 V8.
    Obviously I have to disable the automatic spoiler feature. If I just disable the wire on the spoiler that controls that will it throw a code?
    Or must I go through a diagnostic tool?
    Mar 2018
    Salt Lake City
    Re: Will Disconnecting Spoiler Throw a Code?
    I believe you'll need to disable the spoiler in VAGCOM or you'll get the spoiler fault light. I know that was what had to be done in my case (2010).
    Hidden Content
    2010 Sepang Blue R8 V10 | 6-speed Manual | Carbon Blades | Carbon Engine Bay | Limestone Interior
    Mods:
    | JRZ RS Pro Sport Suspension | VF Hex Tune | Fast Intentions Exhaust | Reid Intakes |
    | Maxton Design Lip, Skirts, and Wing | Xpel PPF | Modesta Ceramic |
    --Other Vehicles--
    2001 Honda S2000
    Nov 2017
    LAX
    Do it through VAGCOM. If you're local to Socal, I can disable it for you.
    Supporting Vendor ULTIMATEPD's Avatar
    Oct 2014
    Houston, TX
    Yes you will get a error message on the dash.
    VAG COM Service in Houston - PM me
    OEM Clutch kits, Pedalbox, TCU tunes, Exhaust systems, OEM Genuine Parts
    Carbon Fiber accessories.
    Hidden Content
    Hidden Content Hidden Content
    IG shardul_amg
    Hidden Content
    Senior Member Wcclubchamp's Avatar
    May 2018
    Anyone know after the codes are cleared if it will continue to throw the codes? I just had a GT spoiler installed and the installer disconnected the spoiler vs using VAGCOM. Will this continue to throw codes until I clear the codes and disable the spoiler?
    Quote Originally Posted by jacobson18522 View Post
  8. #6
    Nov 2017
    LAX
    Quote Originally Posted by Wcclubchamp View Post
    Yes it will continue to throw the code. Car goes through checks and when it doesnt detect the spoiler, it will give the code.
  9. #7
    Jun 2019
    Are you local to los angeles? If so what do you charge?
  10. #8
    Nov 2017
    LAX
    Yes, I am located by LAX. Sent you a PM.
  11. Remove Advertisements
