Head Unit upgrade / Battery Drain
Results 1 to 5 of 5
Thread: Head Unit upgrade / Battery Drain
    Member Wanderingmind83's Avatar
    Feb 2019
    So I think there might be a fault with my head unit - even when the car is off and keys are out of the ignition I can still hear the DVD drive sometimes whirring like it's reading the disk.
    I had a battery drain issue which I thought was the aftermarket exhaust valves, around the same time I got a trickle charger so it sits on that now anyway when not it use, so what I thought might have been a case of leaving the car with the valves open, turns out this might not be the cause...
    But I'm pretty sure the head unit is gong to drain the battery down, perhaps a good time to upgrade it for a better version.
    Does anybody know if newer R8 head units will go is as a straight swap? Having one with built in bluetooth capability for music would be awesome.
    has anybody done an upgrade on the standard MMI that came with the 2008 models? (has a CD changer between the seats)
    Many thanks!
    V8 | Stage 1 Remap | Daytona Grey Body & Blades | Manual 6 | Valved Capristo Exhaust | Extended Leather | B&O
    Bristol UK
    Senior Member Tweaky's Avatar
    Sep 2013
    Hampshire UK
    Re: Head Unit upgrade / Battery Drain
    Definitely worth getting in touch with Hazzydayz near St.Albans. I had mine upgraded by them. They are very knowledgeable and were great to deal with.
    Link.
    https://www.hazzydayz.com/
    R8 V10 6MT shortens straights and straightens curves.
    Neidfaktor complete stitched leather interior.
    Audi OEM carbon parts:
    'exklusiv' rear diffuser|carbon front lip|carbon engine bay|
    Aftermarket carbon parts:
    Interior engine bay lid|illuminated outer sills|inner sills|door trims|trunk surround
    Other parts:
    stitched alcantara trunk|stitched steering wheel|embroidered logo alcantara mats|
    MMI 3G|phone cradle with SDS high|1Tb hard drive|Kufatec TV|interior light and switch upgrade.
    Supporting Vendor
    Jun 2016
    Worldwide
    Newer head units can be installed with no issues.
    You will need to make a couple of small coding changes though.
    Supporting Vendor
    Jun 2016
    Worldwide
    Feb 2019
    Quote Originally Posted by R8-Stuff View Post
    Do you know what the coding changes are? Is that done through VAG software?
    Also... I dropped you a DM about mag rides!
    Bristol UK
  8. Remove Advertisements
