R8 v8 twin turbo std ecu mapping uk
Results 1 to 6 of 6
Thread: R8 v8 twin turbo std ecu mapping uk
    Jul 2019
    Question R8 v8 twin turbo std ecu mapping uk
    Hello guys,
    Can anyone direct me to a reputable person who can map twin turbo setups on the standard ecu?
    I am in the South of the UK but could travel if i am limited geographically to tuners etc
    Thank you in advance and i look forward to your replies
    Matt
    Senior Member DaveL's Avatar
    Mar 2015
    Fortaleza, Ceará, Brasil.
    Re: R8 v8 twin turbo std ecu mapping uk
    If it's possible, Ricky at REP, Ricky at REP, Ricky at REP.
    Jan 2019
    I would be very careful with a turbo setup using stock ecu. Yes it can be done but a standalone would be a way better option as it has more safety protocols that a competent tuner could set to keep your car from having any harm done. If it was a 2JZ or something you can find a replacement way cheaper then a Audi engine.
    Jul 2012
    New Zealand
    Ricky at REP, hands down best person to use.
    Member TechNick's Avatar
    Feb 2018
    GB
    Yup @Ricky.REP can do this - he's mapped mine more than once on OEM ECUs and is in the process of getting an in-house dyno fitted too
  8. #6
    Senior Member Ricky.REP's Avatar
    Dec 2013
    Swindon, UK
    Thanks for all the mentions guys.....have been chatting with Matt on PM so hopefully he will give me a call to run through everything.
    Cheers Ricky
  9. Remove Advertisements
