Hit a curb with my 2018 r8 plus!!!please help
Results 1 to 10 of 10
Thread: Hit a curb with my 2018 r8 plus!!!please help
    Aug 2019
    So I have a 2017 r8 plus. I was taking a right turn that i do every morning on my way to the gym. I was going 20 miles or so slammed against the curb on the right side. Now the whole steering wheel is almost crooked for the car to drive straight, the stability control said it malfunctioned. I am attaching a few pictures. I had a friend look at the control arm looked fine, not bent. Do you guys think it is just the alignment?
    Attached Thumbnails Attached Thumbnails Hit a curb with my 2018 r8 plus!!!please help-img_1848.jpg   Hit a curb with my 2018 r8 plus!!!please help-img_1851.jpg   Hit a curb with my 2018 r8 plus!!!please help-58843460093__3ead7bfa-e039-498b-b126-5bee24895652.jpg   Hit a curb with my 2018 r8 plus!!!please help-58843458236__b91ca820-30fb-4c56-8676-29e1e3890c36.jpg
    Jul 2019
    SoCal (Oak Hills)
    Re: Hit a curb with my 2018 r8 plus!!!please help
    If I had to guess based upon the info given, you more then likely bent a tie rod. Jack the front of the car up and take the wheels off. Compare the left side to the right side. Something bent causing the steering wheel to be off center, now it's time to find it.
    2012 F350 Diesel CC LB DRW Lariat FX4 with A/C seats
    1991 Toyota Pickup CARB legal 3.4 TRD supercharged swap desert adventure truck
    1999 Toyota 4Runner Limited AWD with custom Turbo setup
    2008 Mazdaspeed3 GT Stock daily
    Future car - V10 Gated Coupe or 50x60 steel building
    Apr 2019
    Orlando, Florida
    Quote Originally Posted by r8pl View Post
    I bent a BBS F1-R wheel on a track day at Sebring (pot hole in front of curbing at Bishops bend) with my 2015 R8 Competition. Your wheel looks bent but that would not cause the steering wheel to skew. Looks like a tie rod. Have the dealer check it out, but in any case a new wheel and an alignment. Sorry for your issue. My 20" BBS wheel cost over $2,000 and is probable the strongest wheel made. The dealer checked the front end and it was OK.
    Dr-Rudi.com
    Junior Member Dgcompany's Avatar
    Jul 2017
    Chicago
    The steering wheel may look like it is off by a huge margin but actually it is a very minor bend in the tie-rod. (maybe an 1/8” off causing toe-in). An alignment shop will be able to straighten it out, but you will always know your tie-rod is not true. Also, the shop may not see any fractures in the metal but the metal is weakened slightly and may continue to bend with potholes and hard driving. If money is tight, get a quote for the tie-rod but have the front end aligned for a hundred bucks. Don’t drive the car hard until you get it properly repaired.
    Senior Member CraigFulton's Avatar
    Jun 2017
    Clearwater, FL
    Wheel, tie rod, a arm, bushings, level sensors...so many things. Lift it up and send pictures with the wheel off.
  8. #6
    Jan 2019
    If it's bent replace it don't wait. I did the cheap route and got the alignment on my day to day car and while the steering wheel is straight now you can still tell it doesn't want to go in a straight line. For a car most of us go probably too fast in it would be better just to take it to someone who can really see what's going on and repair it.
  9. #7
    Aug 2019
    UPDAtE
    The dealer finally got back to me. They replaced the Tire rod, but the all-wheel-drive malfunction was not going away, and stability control malfunction light was still noot going away. They now say the steering rack needs to be replaced and it will be about 7k!!!!. They said since the tie rod was hit at such a way it could have bent the steering rack, and a new one is needed now.
  10. #8
    Junior Member Cliff.R8's Avatar
    Sep 2019
    SoCal
    ****, sorry to hear.... Does that $7k quote include repairing or replacing the rim also?
    18’ Raptor SCREW
    12’ R8 V10:
    Fabspeed Catback
    KN Air Filters
    H&R Suspension
    Honeycomb Front Grill
    Previous-
    11’ GTR FBO &E85
    09 Lexus ISF
    08 E90 M3
    06 Charger SRT8
  11. #9
    Aug 2019
    no, the rim is completely fine just needs refinishing. But is it possible to bed the steering rack with a hit like this?
  12. #10
    Mar 2012
    PA
    You might just need to drive it a bit to clear the lights, or turn them off with vag com and see if they come back.
    2017 Ibis White Spyder - Black with red contrast stitching and carbon.
