Headlamp change ?
Results 1 to 3 of 3
Thread: Headlamp change ?
    Aug 2019
    Headlamp change ?
    hi
    is it easy to change xenon bulb?
    i want replace 4300K whit 6000K
    any guide?
    thanks
    Jan 2019
    Re: Headlamp change ?
    I would guess you just remove the plastic trim on each side of the trunk should be able to see the wires running to the light. Just makes sure you wear gloves and thoroughly clean the oils off the bulb before installing a the new one.
    Aug 2019
    thanks ...
