Question about Larini Valvetronic
Results 1 to 10 of 10
Thread: Question about Larini Valvetronic
    Senior Member Rule12b's Avatar
    Apr 2017
    West Hollywood
    I feel like this is probably a stupid question but what the heck. . .I have the Larini Valvetronic on my GT. It came with two remotes so it cane run in the open, or closed position. Candidly, I think the car is quicker out of the hole with the valves closed and much quicker as the revs climb with them open. Can I eliminate the manual control and simply have it vacuum actuated like a factory system? The exhaust would be PERFECT imo if it was closed to say 3500-4k and then open the rest of the way up and under heavy load.
    Apr 2017
    West Hollywood
    Re: Question about Larini Valvetronic
    OK, I'll bump this. I'm considering making a change. I love the exhaust, but with the valves open, my GT is a tad laggy out of the hole. All in all, I'm looking for something with automatic valves, that would function well with FI when I add the VF kit in the future. I love the wail of the Larini at WOT, but want something that's a bit less resonant at 100+ mph over stationed periods. Thoughts? Fabspeed I've heard and it's not what I'm looking for. I'm curious about the Frequency Intelligence Exhaust because it is RPM governed or manual. If I could RPM govern the Larini I'd probably just keep it. Heads up if someone thinks they might want mine. . .8 k miles, perf condition, with the ceramic coating, two remotes. . .
    Jan 2019
    I've got a capristo and I feel that the car needs the valves closed to get going and then open around 3500-4500 RPM. Acceleration from a dead stop is a bit soft when the valves are open. I'm not sure about the other exhausts out there but I love that you can adjust the pressure where the capristo opens. I set my default mode to sport and set the valves to open at 45 mbar (default is 80 or 85 mbar for sport, 150 mbar in cruise). Stays quiet on the freeway but lets out a real scream when I punch the gas. Left cruise alone just in case I want to hear my girlfriends voice that day
    Apr 2017
    West Hollywood
    Exactly my feeling but the Larini is only manual with the remote (or so I was told). If I could figure out a workaround like pretty much EVERY other valvetronic has (throttle position and/or RPM), the exhaust would be stellar. Seems pretty lame in my opinion.
    Quote Originally Posted by vpatel3473 View Post
    Jan 2019
    Quote Originally Posted by Rule12b View Post
    How is the Larini opening and closing the valves? If it's just using the existing vacuum lines just order it without the optional controller and order a controller from capristo. Another option would be get a Larini and take it to someone who can remove the valves and get some valves from capristo so they can be controlled like what I said before.
  8. #6
    Apr 2017
    West Hollywood
    I'll see if this is an option. My larini is simply controlled by a remote, like a car alarm remote. However, I'm not sure whether the actuator is vacuum or electrical.
  9. #7
    Supporting Vendor VividRacing's Avatar
    Jun 2019
    Gilbert, AZ
    They should be vacuum operated. It sounds like you may have their kit that overrides the factory settings. Typically, this kit just opens the valves manually and when they are 'closed' it is using the Auto setting from the factory.. Unless, of course, there is some custom work that occurred.
    Ryan 'Michael'
    Audi Performance Specialist
    Vivid Racing | Gilbert, AZ | Hidden Content
    480.966.3040 x270 | Email: Hidden Content
    KW | Vorsteiner | Brembo | BBS Wheels | Airlift | Bilstein | Armytrix | Tubi Style | Liberty Walk |Quicksilver | H&R | 1016
  10. #8
    Apr 2017
    West Hollywood
    Quote Originally Posted by VividRacing View Post
    No custom work that I know of. They are simply open or closed depending on the manual setting. IF closed, they do not open up at higher revs. Car always starts with them open. Maybe because I have the remotes, it supersedes the factory connection? I'm totally frustrated with the lack of information. I reached out to the shop I purchased it from and they simply don't respond.
  11. #9
    Jun 2019
    Gilbert, AZ
    Per Larini:
    "The valves in a Larini 'Valve Control' Exhaust System function exactly as per the factory valved exhaust – they open and shut at predetermined rev loads, and function via the vehicle's pneumatic feed pipes.
    One may purchase an OPTIONAL valve remote module kit which, once installed, will allow the driver to override the standard features by remote activating the valves so they either a) stay 'OPEN' always or b) return to original 'AUTO' functionality. (Please Note: We do not recommend driving at full throttle with the valves permanently shut, as this will provide a restriction to gas outflow)"
    I wonder if there is an issue with the system or if something was overridden during install.
    Ryan 'Michael'
  12. #10
    Apr 2017
    West Hollywood
    Per Larini:
    Interesting question. When I start it up, the valves are definitely open and they stay that way. If I close them, then they stay that way too. I wonder if the GT-specific stock exhaust was valved? If not, then there is no "stock" actuation. I may go see the installer and ask some questions. . . .
  1. FS: larini clubsport with valvetronic
    By ucf3 in forum For Sale - Parts
    Last Post: 03-15-2019, 07:39 AM
  2. Larini Valvetronic Exhaust
    By kpg81 in forum For Sale - Parts
    Last Post: 07-31-2018, 12:20 PM
  3. Larini Install Question - No heat Shield?
    By bctboston in forum Exhaust Systems
    Last Post: 05-19-2015, 06:08 PM
  4. Larini Exhaust Gallardo w/ Larini Cats
    By losangelescar in forum For Sale - Parts
    Last Post: 03-17-2014, 02:02 PM
  5. Larini Clubsport Valvetronic V10, quick review (UK)
    By andrew186 in forum Exhaust Systems
    Last Post: 10-07-2013, 11:46 AM
