R8 v8 turbo project - Page 12
Page 12 of 13 FirstFirst ... 2910111213 LastLast
Results 111 to 120 of 130
Thread: R8 v8 turbo project
  1. #111
    Junior Member ForceFed's Avatar
    Mar 2018
    Bellingham, WA
    Re: R8 v8 turbo project
    Quote Originally Posted by MADMATT_RS View Post
    ahhh ok mate totally makes sense now i couldnt understand before! How do you find not having watercooling on the turbos? any issues?
    The water cooling is generally due to them being ball bearing vs journal bearing. Also why the oil line orifice used for either is different.
    So it’s not so much as to a concern regarding the cooling as it is what’s your goal for the build. There’s benefits to running BB turbos, but at a cost, which includes the necessity of running water.
    Member Napstar's Avatar
    Sep 2017
    Sweden
    I drive with separate watercooling system with a circulation pump and 2 small heatexchangers for the turbos which I’ve connected via ignition and a thermal contact that turns off at 75 degrees even if ignition is off so that the water does not boil when I turn off the car!
    The Oil is not enough cooling since I have a restrictor of 1mm due to BB turbos.
  4. #113
    Senior Member TheCzarofMexico's Avatar
    Oct 2016
    Houston, TX
    I would say that while water cooling is a good idea, it is always optional whether using journal or BB. The only exception is in my case where the center sections are oil-less.
    Bill Winters - 2012 V10|R-Tronic|Cactus green w/ carbon blades|CCB|Forgeline VX3C's & R888's|LPF Twin turbo kit tuned by Eurocharged: 753/531 @ 1/2 bar
    Jul 2019
    Quote Originally Posted by ForceFed View Post
    Yes absolutely mate and i agree, especially when you are restricting down the oil supply to 1mm for the BB turbos there is just too much heat build up in the core area so water cooling is defo needed. I just want reliable power and longevity so will defo go the water cooled route and build a closed loop system purely so i can continue to run the system after shutdown and keep the twins happy thanks for the reply dude
  7. #115
    Jul 2019
    Quote Originally Posted by Napstar View Post
    Awesome mate this is what i am planning too do you have any photos of your setup? i think i will go for another DC EBP40 for the turbo water cooling too or have you gone bigger capacity?
  8. #116
    Jul 2019
    Quote Originally Posted by TheCzarofMexico View Post
    What turbos you using my dude? 753 hp? HOLY SH!T i bet thats a rocket lol so the turbo cores are oil-less?
  9. #117
    Oct 2016
    Houston, TX
    They are Comp oil-less (3.0 version) 64/70 .82 A/R which have zerk fittings on the center sections that you squirt their custom grease into every 3k miles and are also water cooled (via engine coolant in my case).
    https://www.compturbotechnology.com/our-ct-r-line
    Yea ~750 is pretty fun. I wouldn't call it a rocket, I hang out with a bunch of UGR guys making ~1100 on pump and 1300 on race gas so...
  10. #118
    Oct 2016
    Houston, TX
    My heat exchanger is in the front grill and my intercooler tank is in the frunk. I have one pump circulating from the tank to the intercoolers and back to the tank, and one pump making the short run from the tank to the HX and back. That way the water doesn't need to make a full trip from the front to the rear and back to cool off.
  11. #119
    CFI
    CFI is offline
    Oct 2017
    LA
    Glad to see you removed your original one from the oven out back.
  12. #120
    Sep 2017
    Sweden
    This saves time 👍 Where did you take the water from??
  1. Replies: 14
    Last Post: 07-19-2017, 01:17 AM
  2. EVOMS Project R8 Twin Turbo - Complete Engine Build!
    By Tork in forum Performance Modifications
    Last Post: 09-14-2014, 07:34 PM
  3. Twin Turbo Project
    By duhawks in forum Performance Modifications
    Last Post: 02-19-2014, 03:15 PM
  4. MRC Tuning doing a SINGLE turbo GT45 based R8 4.2 V8 turbo kit
    By motormadj in forum Performance Modifications
    Last Post: 09-12-2013, 01:46 PM
  5. Twin turbo project finally finished
    By g-force in forum Performance Modifications
    Last Post: 02-14-2012, 06:05 PM
