Pedal Box - Cause intake runner fail?
Results 1 to 7 of 7
Thread: Pedal Box - Cause intake runner fail?
    Aug 2018
    Long story short.
    Intake runner fail, right side of the engine. Audi believed that the fail could have something to do with the Pedal box or any other outside source that adjust and boost the throttle and/or reactions of the gas and intake parts. I do not believe the Pedal box has anything to do with the failure.
    The solenoid tested fine, we are replacing box sensors, solenoids and intake runners. Additionally, we are doing gaskets and injector seals.
    Thoughts?
    v10 REV9
    Rohanna 20x
    BC Coils
    Supporting Vendor ULTIMATEPD's Avatar
    Oct 2014
    Houston, TX
    Re: Pedal Box - Cause intake runner fail?
    Did the actuator arm of the intake runner flaps break?
    VAG COM Service in Houston - PM me
    OEM Clutch kits, Pedalbox, TCU tunes, Exhaust systems, OEM Genuine Parts
    Carbon Fiber accessories.
    Hidden Content
    Hidden Content Hidden Content
    IG shardul_amg
    Hidden Content
    Aug 2018
    The software shows the right side stuck close and the left starting to have lag, this was before carbon clean, after carbon clean, they do not match up but the right showed huge lag and eventually stuck closed again I believe.
    Shop foreman spoke to me about it and that is the news.....
    v10 REV9
    Rohanna 20x
    BC Coils
    Member matthewmalk248's Avatar
    May 2018
    White Lake, MI
    Just happened to read this as I have the pedal box in my amazon cart ready to check out! Any updates @donovan?
    2014 R8 Coupe S-Tronic - Bone Stock
    Aug 2018
    Hello
    Replaced intake runner flaps, solenoid and sensors even though The solenoid and the sensors were fine
    v10 REV9
    Rohanna 20x
    BC Coils
  8. #6
    May 2018
    White Lake, MI
    Quote Originally Posted by donovan View Post
    Hello
    Thanks for the update!
  9. #7
    Aug 2018
    Absolutely and I'm now running stronger than ever!
    v10 REV9
    Rohanna 20x
    BC Coils
  10. Remove Advertisements
  1. FS: Pedal Box, Brand New, Still in Box
    By PunjabiM3 in forum For Sale - Parts
    Last Post: 02-10-2017, 12:55 PM
  2. R8 driver crashes and does a runner.
    By Simpleman in forum General Discussion
    Last Post: 09-06-2012, 01:36 AM
  3. Help out for a Good Cause
    By anxjr in forum General Discussion
    Last Post: 10-18-2011, 06:45 PM
