My twinturbo build - Page 3
Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 72
Thread: My twinturbo build
  1. #21
    Senior Member Napstar's Avatar
    Sep 2017
    Sweden
    Great startup btw 😂👍
    Oct 2014
    ny
    You think its same on v10? And thank you btw
  4. #23
    Oct 2014
    ny
    Received some of my fittings and a catch can i will modify to be oil collector pre pump
    Attached Thumbnails Attached Thumbnails My twinturbo build-ab40139b-257e-4fdc-b0c4-aba515140158_1565996221709.jpg
    Sep 2017
    Sweden
    Are you going to run the oilfeed thrue these? I recomend that you use pressed hoses to the feed! I have a friend that had a hosefail and a fire started.
  7. #25
    Oct 2014
    ny
    Hahah i guess not anymore i will order feed line problem is im not sure how long i need as i still havent figured out where to get the feed from here is photo from my oil filter housing
    Also are you running anything on the feed to prevent from oil going into turbos when the car is off ? Like a valve ? Maybe also a valve on the return
    Attached Thumbnails Attached Thumbnails My twinturbo build-ab065c14-e8a0-423c-962a-7007498a1a07_1566076859715.jpg   My twinturbo build-ab134d86-a574-4e91-bd6f-7c946d1629fd_1566076881437.jpg
  8. #26
    Oct 2014
    ny
    Some updates from today finished turbo flanges to the stock downpipes and started working on the x pipe which is 3.5 inch
    Attached Thumbnails Attached Thumbnails My twinturbo build-496f10f7-9b0f-4064-bdca-9185547bef95_1566076946541.jpg   My twinturbo build-837aa250-0568-4e24-8bb6-8a5692458075_1566076968431.jpg   My twinturbo build-e085eb28-1906-4b04-ac6c-51a12f40c864_1566077013820.jpg   My twinturbo build-cbac7c13-ecc0-47ce-82a5-cc702f84a124_1566077030746.jpg
  9. #27
    Oct 2014
    ny
    Also took the front bumper off to measure the size for heat exchanger still confused where to run the water lines
    Attached Thumbnails Attached Thumbnails My twinturbo build-7ce2d3b6-d417-43bd-9e5d-f1aa97a5266f_1566077059307.jpg   My twinturbo build-d2d098cc-8bda-4671-8ad1-7aa2d46e076b_1566077095211.jpg   My twinturbo build-d56c495e-c884-4074-995c-721363ee24cd_1566077139348.jpg
  10. #28
    Sep 2017
    Sweden
    Looks great 👍👍
    What ive read they use to take the oilfeed from the side of the engine via a banjo!
  11. #29
    Jun 2019
    Re: My twinturbo build
    Great work!
    How about moving the turbos further away from each-other, might give you a straighter piping from the engine to the turbo.
    Check the cylinder head for oil feed, there might be an option.
    My twinturbo build-2018-sh_sema-sheepey-built-ferrari-458-twin-turbo_trevor-ryan-017_2409-680x453.jpg
  12. #30
    Oct 2014
    ny
    it will be very difficult for me to move them apart as i would have trouble running cold side piping to intercoolers and would likely need custom intercoolers
    also i do not think the 2 90 degree bends pre turbo will make much of a problem
    i think i will take oil feed from the oil pressure sensor
